Question about Konica Minolta Magicolor 2530 DL Laser Printer
Too dark How can I adjust the amount of saturation to the paper? I am printing using the Adobe InDesign and Acrobat Professional 7.0. I have tried going into the "printer features" and reducing the resolution to 600 x 600 but it's still too dark. I have also tried reducing the resolution from my main InDesign document, exporting to .pdf at it's lowest setting, and it's still too dark. Any suggestions?
    Champion:
  • 214 Answers
Try printer driver settings, there should be a quality menu,
also there is a quality menu on printer menu
Posted on Feb 29, 2008
SOURCE:
I see where to change color density settings in thick paper. Can I do this for plain paper? (Normal printing is too dark.)
The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
Jan 20, 2012 | Konica Minolta Bizhub c203 Copier
Compatability with windows 7
Adobe Acrobat 7.0 Professional is not compatible with Win 7
Adapted from Adobe FAQ
Acrobat 9.2 is the first version to support Windows 7. If you own Acrobat 7 or Acrobat 8, Adobe recommends you upgrade to Acrobat X through your Adobe reseller or the Adobe Store. Upgrading to Acrobat X will ensure compatibility with Windows 7 and access to the latest product enhancements. Enterprise customers with a Gold or Platinum support plan can contact Customer Support for upgrade tips and planning help.
Hope it helps.
May 13, 2011 | Adobe Acrobat 7.0 Professional
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
How to get authorization code for adobe acrobat professional 7.0
try searching keygen on rapidlibrary or use FOXIT PDF Suite(i'm personally using it. it works like acrobat). This suite contains pdf reader, writer, creator nd pdf orginzor.Nd most of all its only 6-7 MB in size. Give it a try.
You can find Foxit PDF SUITE on rapidlibrary
Oct 27, 2009 | Adobe Acrobat Professional 7.0 for PC
My beloved Brother hl 5250dn has refused to print
The printer needs more RAM memory. Check into purchasing and installing more RAM. Printers use RAM to print graphics.
Aug 14, 2009 | Brother HL-5250dnt Laser Printer
Cannot Create PDF from Word Document Using Adobe Professional 6.0
You can try to create PDF file directly from Microsoft Word. Adobe Acrobat Professional installs a virtual printer on your computer. Print the document from Microsoft Word, but make sure you select appropriate printer from the list. It should be called "Adobe Acrobat PDF Printer", or similar.
Jan 15, 2009 | Adobe Acrobat 6.0 Professional for PC
I cant export a pdf from quarkxpress 6.0 Have tried everything. Its telling me to go to postscript printer??? I have made a postscribt and it does nothing. HELP
you need Adobe Acrobat Professional or Adobe Indesign in order to export or convert your documents to PDF format. There are several ways to do it, you can even use Adobe PDF printer and create PDF versions of anything you print.
Dec 29, 2008 | Computers & Internet
Can't print from Indesign CS3 to Epson stylus photo 2100
It sounds like a buffer overun problem. Try reducing the resolution of your graphics. Have you contacted Adobe? You have one year free technical support with the software, I believe.
Jun 19, 2008 | Adobe Photoshop 7.0 for PC
Creating pdf from scanner feed
Instead scan all images with standard settings, combine into one acrobat and then apply the settings to whole PDF
Mar 27, 2008 | Adobe Acrobat Professional 7.0 for PC
Konica Minolta Magicolor 2530 DL Laser Printer Logo
415 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
