Question about Olympus C-7000 Zoom Digital Camera
Camera monitor When we power up our camera the monitor is black and if we take a photo with the black monitor and view the photo it is also black? Any help would be appreciated
Try putting the dial to P.
Posted on Oct 25, 2007
SOURCE:
My nikon coolpix s6300 won't let me view the pictures i have taken on the camera.
I can only offer this: (sorry if it does not help)
When the micro USB Cable is plugged into the camera you MAY be able to take photos. The camera MAY work normally EXCEPT for the MONITOR or Screen. The screen is TURNED off when you plug in the cord.
Nov 01, 2017 | Nikon Coolpix S6300 Hd Digital Camera
The monitor display is black, I want to view the shot I am taking with the monitor not the viewfinder.
Rotate the Live View switch located just above the circular multiselector.
Full details are in the "Live View" section of the manual (beginning on page 37 in my copy).
Sep 28, 2012 | Nikon D3100 Digital Camera
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Olympus FE-46 everything is normal but I do not have any view in the monitor? Shutter is open and I can view photos, and it will take photos, all info is in the monitor shutter speed and the like. It will...
Try going to the Olympus web site follow menus options to the Down loads and or Support pages for your camera.
1) Check for firmware upgrades.
2) Site forum, someone may have had and solved the same problem you've got.
3) Us Olympus support "contact us" to explain your problem, see if they've got a solution.
Mar 29, 2010 | Olympus FE-46 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
Problem with lcd monitor
in the rear side display mode switch is there. you just press the switch once or twice.you can able to see live images
Apr 28, 2008 | Canon PowerShot A460 Digital Camera
Camera monitor
Can you see thru the view finder if this camera has one?
If you can't you probably have a damaged or misaligned lens in the camera.
If you can you probably have a defective CCD. The CCD is what takes the image the lens sees and turns it into a digital image.
Both need to be fixed by a trained technician.
http://www.precisioncamera.com/ is the best nationwide camera repair shop I know of, you can always check locally for a camera shop as well.
Nov 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Monitor is black w/ no image
This qualifies for the service advisory @ http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html. I had the same problem and they repaired it free of cost. Send it to them today.. Good Luck...
Apr 04, 2007 | Nikon Coolpix 5700 Digital Camera
Olympus C-7000 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
