If your shredder plug has a fuse I would check that first, it may have blown if you turned it on again while it was wet
What I personally would do is take the shredder part and run it under a tap to clean of any coffee residue then shake it dry before putting it into a warm dry place like an airing cupboard for a 3 or 4 days to ensure it is completely dry before trying it again.
If it still doesnt work
Darn BlackBerry posted before I was ready. If it still doesn't work open it up and see if you can find any other fuse inside it to check or replace.
Before rinsing it though I would leave for a couple of hours after its last switch have on to try to allow any capacitors inside to leak away any residual charge. Anyway that's what "I" would do. - Otherwise you could try claiming for coffee spills if it's still under guarantee. Good luck with that!
Ignore "have" after "switch", sorry.
