Question about Zanussi FLA1001W Front Load Washer
MEGA LEAK HELLO I MOVED MY WASHING MACHINE AND NOW I HAVE SUCH A BAD LEAK IT LOOKS LIKE IN 2 PLACES 1ST IS AT THE TOP BACK WHERE COLD PIPE GOES AND SECOND FROM THE BOTTOMAND YOU CAN HERE WATER HITTING THE PARTS INSIDE DO YOU NO WHAT THIS COULD BE THE LEAK AT THE BOTTOM IS VERY BAD ALOT OF WATER IS COMMING OUT
  • 209 Answers
Remove the lid, look for any pipes off, if not sure, keep fingers out and look for the leak while starting the machine up to fill, with plenty of light you will find the leak, you will see it, switch off without delay once you have seen it, unplug the machine and do what you have to do to put the matter right, refit any pipe or replace any broken connector etc etc hope i have helped, please note switching the machine on with the lid off looking for leaks should only be done for the shortest of time for safety reasons, keep fingers away and do not touch anything inside the machine without unplugging from electricity supply
Posted on Sep 29, 2007
How to remove washing machine from jayco sterling 2013
I PRESUME YOU WAN'T TO REMOVE A OLD WASHING MACHINE,
1. PULL OUT ELECTRICAL SUPPLY PLUG.
2.PULL MACHINE OUT A BIT TO GAIN ACCESS TO BEHIND MACHINE, SOME MACHINES HAVE COLD WATER SUPPLY PIPE ONLY BUT MOST HAVE HOT AND COLD SUPPLY PIPES.
THERE SHOULD BE A SHUT OFF SUPPLY VALVE AT THE SUPPLY SIDE OF THE TWO HOSES, CLOSE THEM BOTH THEN DISCONNECT HOSES, DRAIN HOSE SHOULD JUST LIFT OUT OF PIPE BEHIND MACHINE , NOTE ALL HOSES WILL LEAK SOME WATER ONTO FLOOR IF LAYED DOWN
A SACK TRUCK IS THE BEST WAY TO MOVE MACHINE
Nov 12, 2016 | Washing Machines
Just bought it and want to know how to fill it with water
gee think you need to hook the water lines up on the back of it
Jun 16, 2015 | Washing Machines
Leaking water onto floor from inside machine
2 common places.1 leak from the pipe/s from the valves to the dispenser box,2 @6 o/clock position in the fold of the door seal is where these models produce a small split.filter not tight.water bubbling over stand pipe when machine pumps out?these machines are usually fairly leak free so might be just one of these things i`ve listed here with luck.
Dec 29, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Watewr is not pump0ing in to machine
that is one of two problems, your solenoid is damaged that open and close the water for you and secondly your mesh that keeps the dirt of the water out of the machine is blocked. 1st remove the pipe at the back of machine and pull out the mesh, if it is blocked clean it and replace, put back the pipe and test, if the problem are still present open the panel and test the solenoid. if you use only cold water and the solenoid is o.o.o i suggest you change the pipe to the hot water side that should solve the problem
Dec 12, 2010 | LG WFT1071TP Top Load Washer
After moving the machine a small leak has started underneath
Could be split. Probably any pipe that was slung underneath. Have a look to find out which pipe and replace it.
Nov 01, 2017 | Speed Queen AWS76NW Top Load Washer
My washing machine is leaking water even with the water shut off and the amchine not running. Is this a drain pipe problem or a oump proplem or another problem?
Hello there
whaen awashing machine does not stop putting water into a machine even after it has stopped then this means that the water fill valve needs to be replaced or repaired this valve has 2 small solinoid valves on it one for hot and one for cold and over time they will start to fail and the result is water entering the machine even after it is off looks like this b9e1869.jpg
May 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine drain hose/pipe leak
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 01, 2009 | Washing Machines
No cold water regardless of setting
2 things it can be if your water pipe were you connect the hose too under the sink has a plastic turn handle to switch the water back on then it is most likely that it has sheard inside it undue the screw that holds it on pull the plastic cover off and with pliers turn until you hear the wate rcome through if not then it will be the solenoid inside your washer that has become faulty were the pipe connects to m8
Sep 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Zanussi FLA1001W Front Load Washer Logo
43 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
