check the float switch on the rinse tank if this shows a open circuit and the tank is full this will stop the heating cycle. again as before all depends on the depending on the make.
check for thermal cut outs, there could be up to 3 located around depending on the make etc, all have different places, 1 normally under the base of the drum lining, 1 on a water pipe below the drum lining, maybe 1 inside the door skin,
also there could be a broken wire inside the door skin just above the hinge, the wires get hot, dry out and snap with wear and tear while opening the door,
Sir , Ihave a requesting in dishwasher working This machine model in miele G77603ph,problem : connecting the electric and water connection ,then press the ON machine is display in –50deg c right side top 1and 2 light is on (1 st kontrollampe “storung wasser zulauf /wasserablauf,2 stkontrollampe wasserentharter auflbereiten) after 2 min no supply insolenoidvalve machine is not workingOne book let is therelanguage in only a germanno write in Enghish language,requesting sir plssend me in English language techanical book let
(working in cold storage mechanic no working experence in dish washer) Jottin francis
Tekno cool system
4th floor ,penta menaka
cochin –31 ph:04844025787
web:www.teknocratsindia.com
email –jottinfrancis@gmail.com
try where thing that it said in the book to do clean the air and drain is not clogged clean that to...
(More)
try where thing that it said in the book to do clean the air and drain is not clogged clean that to the lights are on but just will not work did the reset is there any thing
