Question about Dell Inspiron 8200 Notebook
Inspiron 8200...can it be fixed?
Right after it was out of warranty, or probably even before, because I had lent it to my son and it was in a stationary spot, there was a "hot" spot in the back underneath, that everytime you touched it the computer would lock up. I took it to a repair place for an free estimate and he opened it up and now it doesn't have sound or touchpad. It also loses the hard drive occassionally and I now boot from the hard drive or the CD. What the heck? I know its a boat anchor but I can't afford a new laptop right now.
  • Gloey Sep 29, 2007
    I'm very sorry, I probably didn't explain well enought. When I said a "hot" spot, I didn't mean literally "hot". There is something in that area that causes the machine to lock up and freeze. It was not overheating. I'm sure he didn't put it back together right, but sheesh, I don't have a clue on how to assemble this myself. *sobs* Thank you.
    Sergeant:
  • 457 Answers
When that guy so you mentioned opened it up did he tell you it is possibly the fan stuffed up on the top of the processor. Thats why it was hot. Replace the fan then you wont have any problems. If you do the one who opened it first did not put the right things back proper thats my assumption. The sound and the touch pad connections were not replaced when he put it together again. Although the fan on the processor may have been going it is not strong enough to cool the processor down.
Posted on Sep 29, 2007
  • Anonymous Sep 29, 2007
    Give it ago just becareful if you need to reassemble it again make certain the connections for the touchpad and keyboard are connected. You will see these connect as a flat paper but unbendable connections that slide into their respective slots or ports. once youve done this it should all go again. Usually when a laptop heats up or stops for no reason like you explained is due to the processor overheating? Good luck
SOURCE:
SOUNDCARD AND GRAPHICS CARD DRIVERS NOT ON XP SP3 DOR DELL INSPIRON 8200
You need to download from DELL website, since there are more than one versions of the 8200, you should use the service tag instead, see here:
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn
Dec 31, 2010 | Dell Inspiron 8200 Notebook
I have a Dell Inspiron 8200. The mouse does not respond. It slides down and to the left and then becomes inoperable. Is there any way to fix the problem? Could I use an external mouse?
you can get some really cool tiny little mouse these days or even one with a ball on top that you rotate,ive got an optical one on my standalone,its got a cable but its pretty smooth.
But first try to configure the touchpad in your settings,thaths the most likely problem that you can most probably fix yourself
Sep 06, 2010 | Dell Inspiron 8200 Notebook
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
My dell 8200 inspiron laptop right speaker its not working
My guess is the speakers or connectors have gone bad. I have seen this in a lot of different laptops.
If you are handy, you can disasemble the laptop, find the speakers, and get a part number off of them. Dell is pretty good about labeling the part numbers. Then do a search on Google and Ebay for the speakers, I am sure you can find some cheap used ones that work.
Here is a manual for disassembly of your laptop, and shows where all the parts go. You will need Adobe reader to read this.
http://www.elhvb.com/mobokive/edwin/laptops/Dell/INSPIRON/8200/8200.PDF
Apr 14, 2009 | Dell Inspiron 8200 Notebook
Upgrading my Dell Inspiron 8200 laptop
I have a Dell Inspiron 8200 P4 2.4ghz and I install 2gig or ram and it works great ddr pc2700 333mhz for $69/gig at bestbuy. I really notice the difference. I also install a 160 gig HDD.
Mar 17, 2009 | Dell Inspiron 8200 Notebook
How do I turn the wireless on the Dell Inspirion 8200
there is no on-off switch for the wireless on the dell inspiron 8200 if I recall correctly. Make sure:
1. The mini-PCI slot (might actually have to open the little door on the back of the laptop) contains a wireless card
or
2. right click on "my computer", properties, hardware tab... device manager. See if there are any devices listed (yellow "!") that do not have drivers installed. Go to http://support.dell.com and download drivers for your wireless card and install them.
Feb 27, 2009 | Sharp Dell Inspiron 8200 15.0 ASV UXGA -...
Cannot boot up Inspiron 8200
Could be a tough one. Can you get into the bios ( F8  or F10 ) while booting and check if the HDD is being recognised in the first place ? If it recognises, then check for Boot sequence. I would also suggest to try the Recovery CD that came along with computer.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
Dell inspiron 8200
Yes buy a PCMCIA adapter card. You can search yourself or just buy one here
Good luck and remember please rate this post
Dec 31, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell inspiron laptop 8200
Sounds like the hard drive failed. If you have any super-important files on there, your local GeekSquad should be able to point you in the right direction to recover those items.
Apr 12, 2008 | Dell Inspiron 8200 Notebook
Open Questions:
See all Dell Inspiron 8200 Notebook Questions
Dell Inspiron 8200 Notebook Logo
76 people viewed this question
Ekse
Clive
Clive
Alun Cox
