Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
theoabear, Seems I ran into this before, check out the following post the cat here posted.....Catriver
http://www.fixya.com/support/t129304-maytag_fridge_french_door_hinge
I have a very similar problem. Water will not run, everything in the crisper drawers freeze, when I called Sears they told me I needed to change my water filter, that didn't work and besides what does a dirty filter have to do with the crisper freezing?
If this happens (water won't flow) check the loading of the shelves ... if you "jammed" a bunch of food into the fridge (ie just after a trip to the grocery store) then the airflow in the fridge will go straight down the back. If you keep the temp set low then the reservoir will freeze up faster. Try repositioning the stuff in the fridge and or setting the temp a couple of degrees higher. Your choice.
