Question about Nokia 8290
I have 2 nokia 8290
I chared them first.I saw the bars going up ,like when its charging.I try to turn the phone on nothig happens.I THOUGHY i SAW ASCREEN FLICKER,BUT THATS IT .iT SHOWS NO SIGN OFWATER DAMAGE.i WILL HAVE TO REALLY GETR INTO THIS ONE.nokIA DOES NOT PAY MUCH FOR RESALE.i DEALWITH A MAJOR CELL PHONE CHAIN.aNS i ONLY SAAW 1 PHONE THEY GIVE YOU MONEY BACK.iF i FIX THESE PHONES,THEYARENOT WORTH ANYTHINGV.IF NOT i WILL DONATE THEM TOAN ORGANISATION THANKS DOUG RUBY
  • 89 Answers
Well in this case there will be many problem . like power button either not working or battery may be not working so your mobile phone can get repaired and i am very sure it won't cost you much
Posted on Sep 30, 2007
My samsung gt-c3303 champ auto charing problem,tell me solution of this problem?
Hello Friends:::::::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 14, 2013 | Cell Phones
My LG enlighten won't turn on
Nokia X2-02 type 694
Dec 04, 2017 | LG Enlighten
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
Oct 13, 2010 | Nokia 6300 Cellular Phone
Nokia 6610i not charging
NOKIA 6610 NOT CHARING PROBLOM
Sep 17, 2010 | Nokia 6610
I have a husqvarna 257 with a 20inch bar and having oiling problems, is getting hardly any to no oil and have the oil adjuster screw the whole ways out, is the oil plunger bad?
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
Sep 14, 2010 | Husqvarna Chain Saw 20" Bar
Chain saw motor runs but chain doesn't
There are a couple of reason the saw blade will not turn.
- Make sure you have bar and chain oil in saw.
-Make sure oil is running on the saw blade and chain.
-Make sure the clutch is not stuck.
- Make sure the bar sprocket is not frozen.
-The safety kick back guard needs to be re-set.
-Shut off saw. Push and pull guard.
Please let me know what you find.
Feb 10, 2010 | Garden
Saw cuts then stops chain still goes around bar then seems to catch agian then cuts
sounds like the clutch is starting to go out. i have one just like it and the same thing happened to me
May 22, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Mar 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Nokia 8290 Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
