FixYa.com
Tags:
Hard Drives
Generic problem for all Hard Drives
Hard drive transfer (by 2 users)
posted by bob13 on Sep 29, 2007
can i tranfer all data from one hard drive to a empty hard drive
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 15, 2008
I am having a problem with Quantum 40 BG Hard Drive
Best Solution
posted on Sep 30, 2007
Helpful (85)
Benimur
Rank:Guru Guru
Rating: 87%, 2148 votes
Yes you can. The only requirement is that the 2nd/new/empty hard drive be similar in storage capacityif not bigger.
If you are planning on swapping from old to new and use thereafter the new as the main "C" drive, you might want to try and simply clone the old. There are software available online for that purpose. One good example is a "Acronis True Image" paid version. A freeware version by Seagate is Seatools for Windows.
Hope this be of some help/idea. Post back how things turned up or should you need further information.
Good luck and kind regards.
Comment by Benimur, posted on Sep 30, 2007
Hi again,
Seatools might not work for you. Do a Google for alternative freeware version HD cloning utility.
Cheers.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Apple (M9741GA) 400 GB Hard Drive Averatec (70-822301-00TRI) (7082230100TRI) Hard Drive Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive Buffalo Technology 750GB USB SATA 2.0 HD DS 750 GB Hard Drive Compaq (349239B21) 250 GB Hard Drive Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive
Can you Help with these Hard Drives problems?
Hard Drives
Dowload Drive for my...
Dowload Drive for my... Answer This...
Acomdata HybridDrive E5 Hard Drive
Computer doesn't see the usb...
usb cable connected to... Answer This...
Maxtor 160GB OneTouch III Mini USB 2.0...
Problem starting up Maxtor 160...
I don't know if this problem... Answer This...
LaCie 500GB FireWire-400 Porsche - 7.2K 500...
Lacie 500Gb Hard Drive Porsche...
Hard drive not being recognised... Answer This...
Hard Drives
External Corrupted
exactly it was say: F:\is... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
