Question about LG Flatron L1750S 17" LCD Monitor
Black line across my screen
I had a little black line on my screen which i thought was a pen mark it has now moved across my screen and is getting thicker anyone know what my problem is
  • marie1975 Sep 29, 2007
    it is actually a lg flatron l1750b
  • marie1975 Oct 04, 2007
    thanks solved it got a new one and gave it away
  • 38 Answers
Hope your flatron is under wtty, get it checked before it is too late. It is a hardware problem which you cannot fix by yourselves.
Posted on Oct 01, 2007
Hi I have a 55 inch LCD TV that while I was watching TV it went completely black when I turned it off and the on again there were rainbow vertical lines moving across the screen then at some points there...
My first thought would be to check your TV on multiple inputs to verify that it IS the TV and NOT isolated to your input cable(s). If you can get a solid blue color to come up on the screen by changing inputs then it would really narrow down the issue(s).
Hope this helps.
Jan 04, 2018 | Insignia NSLTDVD26 LCD TV
Hello, I hava a problem with our KX-B530. The indication for the cause "screen does not move" is blinking in the error indicator field. When i'm pressing the copy buttons nothing happens but...
Hi, on the bottom of your screen- just hidden inside the lower plastic trim, should be a black felt tag that lets the sensor know where the page should stop. Sometimes these curl up and fall off. You should see that at least one tag is on one of the screens. Mark on the plastic frame where that black felt stops with your finger or a bit of sticky tape. Turn off your machine and move the screen by hand. You can tell where it should stop for the next page as usually the screen has some minor rounded folds where it sits on the rollers.
When in position- use a permanent black pen to draw a small 1cm high by 3cm wide black box as low as possible on the screen where the old tag fell off. It may still be there rolled up- you could then reglue it if it is there.
Sometimes no felt is visible, but the previous glue/sticky gives you a clue- usually about 5cm to the left of centre you will find it. If your put the permanent pen in the wrog place, metho will remove it. If you are worried- try a w/b pen first. Perhaps only a small part of ther felt is missing.- Ross
Feb 08, 2011 | Panasonic Panaboard KX-B530 Graphic Tablet
I get black marks like a crayon or ink line on certain light colored shirts after washing my clothes. Not sure if it's coming from washer or dryer. I use a stain remover and it's not coming out completely.
is the black marks grease look under the bottom of the machine and look on the side walls of the machine if u have a line of grease around both sides then you would need to change the transimission on the machine if it is not grease and you determine that is pen u might try looking in between the two baskets.And lastly ihave seen pen cartriges enlodge inside the pump which does cause the pen to leak hope this helps
Jun 26, 2010 | Washing Machines
Tablet Pen moves very slowly across the screen. It used to work fine, but the last few times I've tried, the mouse ends up moving faster. I used to be able to move the pen across the tablet and the mouse...
This may be a processor issue, as mine does this too.
As for others, most issues surrounding the stylus are battery related.
I will help anybody with a broken, or inoperative stylus/pen get their pen operating again. I have started a business around this issue because so many people's pens are malfunctioning (including mine originally which drove me to do this). This was fueled by Gateway's lack of caring around the issue, and their attempts to charge ridiculous fees for customer service. I charge $20 to switch out the battery to get your stylus working again, plus shipping and handling both ways, about $25 total.
Email me at: kevin teman AT hotmail DOT com
Or,
See my website at:
[url=http://www.kevinteman.com/stylusrepair]Stylus Repair and Battery Replacement[/url]
Thank you, Kevin Teman kevinteman.com/stylusrepair
Feb 25, 2010 | Wacom (EP130EPE) Digital Pen
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
Photoshop and WP5540 compatibility
get PS cs3, never had problems with that one, i own a genius 8X6 and it was perfect, yeah i know it sucks cause i brought cs4, but well, gotta wait till those guys from adobe fix that problem
Jan 24, 2009 | Computers & Internet
My Xbox/Screen Problems PLEASE HELP!!!
Will need to be serviced. Its the Solder under the GPU. We can fix this for you. email us if interested
xbox360fixer@verizon.net
Jan 19, 2009 | Microsoft Xbox 360 Console
Pen continues to draw without pressure, simply by movement.
Make sure that you do not have anything around you that has blue-tooth or a blue-tooth option. Cell phones, mp3's etc. These can give off false electromagnetic signals causing it to think that you did something that you did not do.
Oct 22, 2008 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Looks like pen marks on inside of screen
What you are decsribing sounds like your picture tube or tubes have been scored (permanent burn marks on the picture tube phosphor). The sure way to tell is to remove the front screen and look into each of the three lenses while the set is on. You will see a black image of your pen mark within the picture. Did you recently have problems with convergence or the set shutting down (turing off by itself for no resaon) ?
Nov 12, 2007 | Toshiba 50H82 50" Rear Projection...
LG Flatron L1750S 17" LCD Monitor Logo
250 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
