Question about HP DeskJet 5150 InkJet Printer
Cleaning printer nozzles.
I have an H.p. deskjet 5150 printer, connected to Microsoft Works. No red ink is coming through. I have tried mannually cleaning but this hasn't worked. Nothing on the printer display on the screen allows for automatic cleaning. Alan
  • Anonymous Feb 28, 2008
    Mine was printing 1/2 the characters, now it's given up doing that as well. Just blank pages with very faint ink-marks. Cannot find anyway to ask it to clean itself.
Hi
I have been filling cartridges for appox 12 years.
Stand the cartridge in 2mm of nail varnish remover preferably in a polythene container.
Leave for 5 mins should clean it.
Still not clean?? Then remove label from top of cartridge this will expose the holes to each chamber. Introduce air into the chambers using a syringe without the needle attached. By forcing air into the cartridge will force the jellified ink out through the printhead
Posted on Mar 03, 2008
    President:
  • HP Master
  • 2,022 Answers
See may be your catridge gets dry it is bettre to just remove it try to clan with any perfume and shake it for 5 to 10 times. if still it is not working i will advice you to buy a new one. bye
Posted on Oct 01, 2007
6ya staff
SOURCE:
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
BLACK CARTRIDGE PRINTS IN SPASMS BUT COLOUR CARTRIDGE PRINTS FINE.
I didn't get your question,even I am trying to give you solution. Switch on the printer, left top cover wait until carriage arrive at middle, remove mono cartridge, take out swab nozzle area with good cotton or ear buds adding with alcohol(solvent) gently in one direction,repeat three to four times & shake well and see ink coming out from nozzle area?, clean nozzle area with tissue paper put it back & check for print..
Feb 04, 2012 | HP DeskJet 5150 InkJet Printer
I have refilled ink in my cartridge but when i try to print nothing comes out i.e it gives faint copies
Ink is full but nib is faulty will pen writes? similarly cartridge refilled with ink but nozzles are clogged/blocked then print wont happen properly..before refilling the cartridge check nozzle status, clean nozzles properly then refill it. Remedy1:Take little warm water pour in small container dip nozzles in water wait some 2-3 minutes clean nozzle area with dry smooth cloth...try it till print quality improves..Remedy2: You can do clan/align process through printer drivers properties..
Nov 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
No color
try to head clean your printer..
follow this steps
1.click start
2.than click printers&faxes
3.right click on hp deskjet printer logo
4.select printing preference tab
5. click on maintenance
6. click on head clean
do it once and try to print some picture with best quality print setting.. and than try to print normaly again.. repeat the steps until the printer normal.
hope this help..
Apr 30, 2010 | HP DeskJet 5150 InkJet Printer
Printing dark and light black ink full
  1. dip the bottom of the cartridge into hot water for about 20 seconds.
  2. Dry the cartridge and put back into printer
  3. you can also try the printer head cleaning option on the printer software.
  4. My 1st option normal works and you won't use up a lot of ink.
Apr 13, 2010 | HP DeskJet 5150 InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
Won't print
U CAN CHECK UR COLUR CARTRIDGE IF ANY OF UR CRTRIDGE IS FAULTY THE RED X WONT GO OR ALSO TRY CLEANING THE SURFACE WITH MOIST CLOTH THAT CONNECTS WITH UR CARTRIDGE CIRCUIT.WISH U SUCCESS.
May 09, 2008 | HP DeskJet 5150 InkJet Printer
Question for printer hp 5150
Ink has leaked into the printer and messages say problems with colour/black ink cartridge. Would cleaning the ink out of the print solve problem and if so what solvent is best to use.
Graeme
Apr 21, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
107 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
