Question about Hoover F5807 SteamVac Wet/Dry Vacuum
Hoover steamvac ls edition, model f5894
Hoe do you remove the steamvac attachment hose assembly and which replacement hose assembly is available. several are listed but all with caviets. my product is not listed so checked the closest. have a hoover steamvac model f5894.
  • Lauren Junge
    Lauren Junge May 11, 2010
    Look on the metal tag on the back of the handle asm. I need to know the complete model number. Because Hoover has several hoses for the F series steamvacs, you will want to get the right one.
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
The original problem was, How do I attach the upholstery attachment to the cleaner. I see where the water connection is, but not where to attach the hose part.,
The solution to attaching the upholstery attachment to the Hoover Steam Vac cleaner was excellent for steps 1 and 2. However, in step 3, I can not simply slide the upholstery attachment straight down. It gets stuck and does not connect to the bottom connector and is stuck in midair. It seems like I am doing something wrong. My Hoover model steam vac model number is F5900-900.
The solution given in steps 1,2, and 3 where I have a problem with step 3 is as follows;
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Feb 16, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
  • 7 Answers
SOURCE: Instructions on how to put attachments on hoover
Remove solution tank.
Remove hose from storage rack.
Remove recovery tank and lay cleaner flat on floor. Remove lid,
Now, remove front panel from recovery tank by sliding it straight up.
Take your hose and slide the U-shaped end (converter) into the place where you removed the panel. Slide halfway down opening until it is firmly in place.
2nd step: You should have a tube with a "plug" on it hanging from the converter end. Open door on hoodl abeled "Stair upholstery/Cleaning Connection". Extend black tabs by pulling tan collar toward tube. Press connector collar down firmly to ensure that it is fully connnected.
It's sort of like a childproofed plug and socket. Pull back on the collar and push in the olug. Not hard at all once you've done it the first time.
Make sure you put the lid on the recovery tank correctly so you have suction. Attach whatever brush you want to use on the other end until the tab locks into place.
Sometimes you have to bleed the air from the line by turning on the cleeaner and letting it **** against your hand or hard surface for 15 seconds before its ready to use. This gets the solution to flow to the tool.
Posted on Aug 06, 2009
  • 430 Answers
SOURCE: Hoover steamvac lower hose replacement instruction
Try 1800 Customer service
Posted on Sep 06, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Why is water pouring out the bottom when I try to use upholstery attachment?
On many hoover models the hose attaches to the vacuum and is held on by a clip on the hose assembly. There may be some damage to your hose or the place where it attaches to the machine. Inspect these areas trying to locate the point of the leak.
Feb 25, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
How do i replace a valve assemblyon a hoover widepath f6020
You don't need a new hose. Remove the two Phillips head screws which hold down the wand cover. Be very careful when removing these parts. Pay close attention on how these parts are assembled. They are spring loaded and will fly out the end of the hose assembly when the cover is removed. The wand valve assembly or the nozzle valve assembly or usually the parts that break. Vac Parts Warehouse Here is a link of the parts breakdown.
Oct 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I need to replace my hose to my steamvac model F5842 can you help? Ordered a hose but I don't think it's the right one
Hi Chris,
Your Hoover SteamVac model F5842 needs the Hoover SteamVac replacement hose part number 40309007. You may find a link to the correct hose for your model below on our website:
Hoover SteamVac F5842 Replacement Hose Assembly
In terms of replacing the hose, this is an older style SteamVac, which attaches the hose to the front of the Dirty Water Solution Tank.
Here is are instructions on how to attach the hose to your machine:
http://www.fixya.com/support/t4699742-dont_manual_u_connect_hose
Hopefully this was helpful, and answered your question. Please don't hesitate to request a clarification, or add a comment if you have any further questions or concerns.
Thanks,
Chris Jones
Oct 07, 2011 | Vacuums
I need a replacement hose assembly for the hoover steamvac jr. any suggestions where i might find the part?
Only through a Hoover warranty/ service center if still available. If not save your hose ends and find a different hose with adaptable ends
Nov 25, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Hoover Superscub attachments won't work
It sounds to me like you have the water hose plugged in, but not the hose block. In the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. If you have already done this, then here is your problem: when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click" your tank is now ready to pick up the dirty water from your hose. let me know if this helps!
Aug 06, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I need yo find out hoe to use the upholstry attachment. Ilost my
I'm not quite sure where the attachment plugs in but, I did find an owner's manual for this Hoover online.
http://www.hoover.com/pdfs/manuals/F5918900.pdf
I hope that helps. Good luck!
May 25, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac Agility won't pick up dirty water
May 01, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Apr 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5807 SteamVac Wet/Dry Vacuum Logo
261 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
