Its a breather pipe im not positive but usually u twist and turn pulling on it to remove, its a interference fit the timing chaine cover is just stuck there is a gasket some times people put sealant on it u will need to use a very thin screwdriver and pries it open once u break seal it will b easy ,..u must re seal after u have finished fitting it or there will b oil every were leaking
SOURCE: Timing Chain Cover, Chain, Sprockets, replacement
2.2L VIN 4
To Remove:
To Install:
SOURCE: front drive shaft/transfer case removal 03 chevy trailblazer 4wd
Sounds like you got it. They are heavy and ocward (spelling?). As for the front drive shaft take the bolts out and give it a couple of wacks with a dead blow hammer then slide it out. Maybe a few days before hand give it a good spray down with wd40 or like product. Also when you get to the last bolt for the t-case to trans loosen it half way then put a drain bucket under it and seperate it a little and let the trans fluid drain some, or you will be wearing it.
SOURCE: merces benz c230 timing chain replacement procedure
so it takes some Pin pullers, or a litlte bit of messing around witth proper sized (heavy duty) bolt to pull the pins, i cannot seem to find the timing marks on mine once i got it offand want to put back on, i have a chilton and it doesnt help. if you buy the 100 -200 dolar shop manual from bentley it would probably be quite simple :)
pull, pins, timing cover, water pump, solenoid, etc. to get to timing cover, uppe and lower,pull valve cover, and loosen cam (exhaust side) to get chain off. :)
