l have a technics cd,tape deck and tuner stack system model number sc-750 and l have just purchased a technics record player deck model number sl-b210. can you pleae tell me if these two systems are compatable with each other as l have followed the instructions on setting up the record deck but am unable to get any sound from it. on the record deck there is a white and red stereo phono lead with only two connections and on the receiver there is several and i have tried all with the lead supplied but still can not get any sound. any advise would be appreciated. many thanks mike
-   Yeah same sort of problem as with first post.
SL-B210 is plugged into my amp (yes it has an AUX/PHONO input) and it is also connected via the ground lead. However I have to have the volume on the cambridge audio amp I have turn up full and then its not that loud................ Any suggestions would be fantastic.
Do I have to use a pre amp unit it increase the volume?
-   77DavidS
Mar 01, 2008
-   I have the same problem with my technics sl-d1 turntable, I have it hooked up to my amplifier (in the phono input). I know my amplifier is not the problem because we have it hooked up to other things and they all work fine,but there is no sound from the turntable other than a humming noise, could this be due to a bad cartridge? is there any test I can do myself to try and find out the problem?-   jb916
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
i was playing cd's in my sa-ak600 in 'all-disk random' mode and the player seemed to loose track of...
(More)
i was playing cd's in my sa-ak600 in 'all-disk random' mode and the player seemed to loose track of where it was up to. I pressed stop and ever since the cd's that were playing are not being recognized, the message is 'no disk'. i tried different cd's and even a cd cleaning disk, same error. these are not copied disks, they are brand new and were purchased from shops. any ideas ?
there is no sound when it is turned on. it doesnt matter what mode it is on whether it be radio, cd...
(More)
there is no sound when it is turned on. it doesnt matter what mode it is on whether it be radio, cd or satellite
