Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Brother Fax Machine
The faxes used to work and now they dont. When i fax something it scans the paper and then makes a beeping noise for a while. I just wanna know whats wrong and how do i fix it.
  • 832 Answers
Is there an error code displayed? Check cable connection at wallsocket and machine, too.
Posted on Sep 29, 2007
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Mar 05, 2010 | HP 1040 Plain Paper Inkjet Fax
How do i fax?
First you enter phone line in to the fax machine and then feed the fax paper on the top side of the fax machine then dail the number on the dail pad after the beep press the start button your fax start work.Fax throughput and office productivity are enhanced by scanning faxes into memory while the machine is busy. You can return to work, confident that their faxes will be transmitted as soon as the line is free.
Nov 25, 2009 | Brother IntelliFax-2480C Fax
How can I fax a Paper?
Load the original face down
dial the fax number
press START
Mar 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
BLACK PAPER
the scanning lamp is most likely not working\
here is the manual go to the maintenance section to see the scanning lamp
http://www.retrevo.com/s/brother+2820+fax++manual
Dec 18, 2007 | Brother IntelliFax-2820 Laser Fax
Samsung Fax machine - not working
Sounds like the machine is trying to talk to the computer make sure the function is set to fax mode this will be in your manual.
Once you have tried this try sending a fax see what happens.
Hope this is some help to you please rate me.
Cheers
J
Dec 07, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Doesnt Know How To Use Fax
Very easy. Make sure you have a phone cord plugged from the wall to a port in the back of the machine marked "line". Place you document in the feed, dial the fax number of the other machine and press start. Your machine will dial the other machine, make some beeping noises then scan your document. If it feeds through ok, and you do not get an error message in the display, then it has been sent!
Jun 19, 2007 | Brother FAX-T78 Plain Paper
Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Jun 14, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
