Question about Lakewood HV-18 Floor / Box Fan
How can I clean a Lakewood fan, mine is so filthy and I cannot get in to clean. My husband says it does not come apart.
    New Friend:
    Problem Solver:
  • 14 Answers
Ok here is what I found....there should be screws on the outside rim where the two fan grates meet....then dust the innerds with a leaf blower or a rag, then use brake cleaner spray to soften the greasy dirt that formed, and again a rag to wipe away any residue....hope this works, it did for me
Posted on Nov 16, 2013
2 Suggested Answers
SOURCE:
dodgecharger
  • 254 Answers
SOURCE: cleaned a fan, now it's broken!!!
Is this the speed switch itself? These multi-speed fans have 4 or 5 wires which come from the motor which go into the speed select switch. The wiring may have the ends stripped, and this stripped end just pushes into the hole on the switch, and a little metal piece grips that stripped end.
Anyway, one possibility is to contact the manufacturer- look on their website or give them a call, see if a tech can give that info. Another poss. is to locate an identical fan and note the wiring locations on it. You can also experiment trial and error, though caution needs to be exercised here.
Posted on Jul 31, 2008
Lakewood mini tower fan #MTF-15 CAN I TAKE IT APART TO CLEAN IT??
How do clean the lakewood mini tower fan model MTF 15
Here is what one said:
"To clean it, you will need a small paint brush, screw driver either flat or crossed, then disassemble it. Loosen the screw and just be observant what you put apart. Then clean it. Good"
You may want to take it to a gas station and REALLY clean it out? OR a aerosol canned "AIR DUSTER" will be very useful too!
Anthony
May 20, 2018 | Lakewood Dryers
How to clean lakewood 2210 fan
Hi, if you look inside the grill from the back side, you will see there are small snaps inside near the edge of the cover. The snaps go around the entire cover and are about 3-4" apart.
I used a flat tip screwdriver to get push the tab up from the back and the inside of the grill. When you push up the tab a bit, then slide a small flat tip screwdriver on the outside lip of the front grill. You will have to do this all the way around until the cover snaps off. Putting it back on is a breeze because it just snaps together.
***AS ALWAYS SAFETY FIRST !! NEVER WORK ON ANY APPLIANCE When it is plugged in !! ***
Hope this helps.... =) good luck
Jun 28, 2012 | Lakewood 2210 Fan
How do i take apart and clean my 2517 lasko t.f.
I took mine outside and hosed it down real good and then let it air dry for a day or 2. worked great! it was filthy!!! and that dang screw made it impossible for me to fully take it apart to clean it, so I decided it was either the hose or throw it away. mine was incredibly dusty and i was able to use a hose with a power nose and spray it really good. we'll see how long it works :)
Apr 30, 2011 | Lasko 2517 Tower Fan
How do I clean the Lakewood tower fan
take apart the parts that come off and wipe them!
Dec 28, 2009 | Lakewood 007 Floor / Box Fan
How do I clean my Lasko fan with Ion?
Yes unscrew the screws and thre will be more screw to undo insode to take it apart. I had to do mine an it was filthy! Good luck!
Apr 23, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Cleaned a fan, now it's broken!!!
Jul 31, 2008 | Lakewood HV 18-c Floor / Box Fan
Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Jul 03, 2008 | Marvin 1210 Floor / Box Fan
Can here motor running but blades do not turn
go and take it apart and clean it afterwards. dont forget to put oil. you might want to check the carbon inside the motor, they may need replacement.
Mar 18, 2008 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV-18 Floor / Box Fan Logo
396 people viewed this question
Top Lakewood Dryers Experts
Bruce Showalter
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
