Question about HP Photosmart 735 Digital Camera
Transfers I have a hp 733 photosmart 3.2 MP with a 3x optical zoom. I have pictures on the camera but would like to transfer them to my computer. I lost the book (yeah I know!). When I go into the my computer hp photosmart is there, I click on that and there is a box that says get pictures from camera. When I click on that nothing happens. The camera says "connected to computer". Brenda K. Nummer brendanmmr@yahoo.com
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You may download a copy of the manual here.
Posted on Sep 14, 2012
SOURCE: lens does not retract
I'm looking for a solution to this too. The repair is going to cost more than the camera did. SUCKS!!!
Posted on Dec 08, 2007
SOURCE: cybershot sony 7.2 mega pixels optical zoom 3X-
i'm having the same problem!! I'd like to know what to do to fix this issue.
when i turn it on "turn the power off and on again" and it says it over and over again when i do it.....the lens doesn't come out anymore . It can show my pictures but thats it.
Posted on Jun 25, 2008
SOURCE: viviteck 3x optical zoom, battery
I got an estimate of $125 to fix the Coolpix 7900 door, and the camera probably isn't worth that much. So I looked more closely at the camera to create a jury rig fix. As I never use a tripod with the camera, I thought about using the threaded tripod mount. I found a very short 1/4 inch thread screw in my garage and cut a thin metal strip to about 2 1/4" x 1/2". I then drilled a 1/4" hole at one end of the strip, laid the strip across the door and tightened the screw through the 1/4" hole and into the tripod mount. The door is now secure. To remove the battery, I simply loosen the screw a little with a dime and pivot the metal strip out of the way. There are many variations that can be done similarly such as using a plastic strip and a plastic 1/4" bolt or even a shorter strip that just covers the door.
Posted on Sep 12, 2008
lock123
  • 6831 Answers
SOURCE: kodax 8.2 megapixel 3x optical
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 07, 2010
Kensolutions
  • 455 Answers
SOURCE: what kind of charger does a Sony Cybershot DSCW80
The DSCW80 Camera is supplied with the BC-CSGB Battery Charger which can be used to charge the battery of the Camera by inserting it to the charger.
You may also use the ACLS5K AC Adapter (not supplied) for charging the battery by using the Multi-connector cable of the Camera.
Thanks for contacting FixYa.
Posted on Feb 24, 2011
HP photosmart 725 battery is not charging
This camera takes a lithium battery and if it is left to fully discharge then you may never be able to charge it up again. Your answer may be another battery. Find a cheap third party battery to try it out.
Feb 22, 2015 | HP Photosmart R725 6.2 Mp 3x Optical Zoom...
Camera says memory full cant take picture
Delete some pictures or insert a new memory card that has space on it.
Oct 02, 2014 | HP Photosmart M737 8 Megapixel Compact...
Transfer pictures from 813 3X optical zoom Camera to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 16, 2012 | Kodak Easyshare C813 8.2 Mp 3x Optical...
Hp 3x optical zoom photosmart R847 camera plug in to PC and cord was check it is working fine but it will no longer establish a connection with the computer Uninstalled disk and reinstalled still...
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 02, 2010 | Cameras
Looking for startup(owners) manual for HP Photosmart M447 Camera adivise: nyjerrymarshall@msn.com
Copy and paste this address in your browser to download a copy of the manual to your computer. http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3403436&lang=en&
Mar 23, 2010 | HP Photosmart M447 Digital Camera - Silver...
Hp photosmart that keeps saying card locked when inserted
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Mar 17, 2009 | HP Photosmart M447 Digital Camera - Silver...
Sharp VE-CG40
I bought this camera off ebay. I do not have any software for it. I cannot get it to transfer pictures to my computer. I think i need to install a driver. It is a Sharp 3x Optical Zoom Digital Still Camera VE-CG40. Where can I download a driver?
Dec 25, 2007 | Sharp VE-CG40U Digital Camera
HP Photosmart 735 Digital Camera Logo
27 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
