Question about Coby MP-C7085 MP3 Player
Battery life OK, so I let my coby mp3 recharge on my computer for bout 3 hours and i can only get through like 3 songs then a picture of a baterry with low energy keeps flashing then it shuts off, i thought my mp3 was defected so i smashed it and bought a new one, and I have the same problem now.
  • lujansteven Nov 19, 2007
    I charged my player over four hours before its initial use and it lasted less than twenty minutes. how do you fix this problem?
The manuel says too charge for 20 hours try doing that it will maybe work
Posted on Dec 02, 2007
  • 3 Answers
On first use, charge 12 hous. Following uses, charge 6 hours.
Posted on Nov 26, 2007
SOURCE:
Low battery life even though fully charged
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 06, 2013 | Sony Walkman Sport Series NW-S205F MP3...
How to delete songs and pictures and videos off my coby mp715 mp3 player
I believe you need to connect you MP3 player to Computer using USB. Then only you can delete your songs. Many MP3 players does not allow you delete songs or any media when they are operated. :)
May 03, 2011 | Coby MP715 MP3 Player
Want to watch movies
Looks like it only plays .mtv files, so a converter may be needed before uploading video files to the 610.
Try these links for converters, info, etc.:
http://www.imageconverterplus.com/help-center/about-icp/supported-formats/mtv/
http://www.openwith.org/file-extensions/mtv
http://www.sharpened.net/extensions/file/mtv
Product Description: Coby MP6104GBLK MP6104G 4GB Color Display Flash MP3 Player Radio.
1.8 inch color LCD display.
Integrated flash memory.
Plays music, video, photos, and text.
Integrated FM radio.
ID3 and LRC support for song and lyric information display.
USB 2.0 Hi-Speed for fast file transfers.
Integrated rechargeable battery.
Color: Black.
Memory Capacity: 4GB.
Display Type: 1.8 inch TFT LCD.
Display Resolution: 128 x 160.
Media Support: Integrated Flash.
Format Support: Audio: MP3, WMA; Video: MTV; Photo: JPG; Text: TXT.
OS Support: Windows Vista/XP/2000.
Menu Language Support: English, Spanish, French, Portuguese, Italian, German.
Additional Functions: FM Tuner.
Audio Output: 3.5mm Headphone.
PC Interface: USB 2.0 Hi-Speed.
Power: Integrated Rechargeable Lithium Polymer Battery.
Battery Life: Capacity: 350mAh; Audio Play Time: 8hr.
Unit Dimension (WHD): 1.65 x 3.66 x 0.38 inch.
Helpful?
Mar 23, 2011 | Coby MP-610 MP3 Player
Have a Coby MP-C7085 that will not turn off. What
Hello :
First you need to wait until the battery is empty to let it shut off .
then you need to replace your mp3 player battery with a new one . When battery life is ended , it can't be recharged anymore .
good luck .
rate please !
Mar 19, 2010 | Coby MP-C7085 MP3 Player
I need some instructions on how play it
1. Use Windows Media Player to put songs on your Coby MP3 player. Download songs in MP3, WMA, or OGG format from a legal downloading website. If the file is not one of the previously mentioned files, you must download a converter to convert the file to one of the correct files that can be played on Windows Media Player. Rip a song from a CD by inserting the CD and then click on the option to "Rip" the song to your library. Some Coby MP3 players do not need Windows Media Player to add songs, so be sure to check your user manual to see if there is an even simpler method.
2. Connect your Coby MP3 player to your computer using the USB connector that came with your MP3 player. The player will show up under the "Devices" option on your Window Media Player application.
3. Click on the "Library" option to view all of the songs stored on your Windows Media Player library. You can drag the song to the MP3 player in the "Devices" section, or you can right-click on the song and choose the option to transfer the song. In the pop-up box choose your MP3 from the drop-down menu and then click on the "Transfer" button.
4. Right-click on the MP3 player in Windows Media Player and choose the "Eject" option. Disconnect your MP3 player from your computer and turn it on. The song will now be available on your MP3 player. Press the bottom button to play or pause the song.
5. Add videos and pictures to your Coby MP3 player if it supports those files. The process is similar to transferring audio files. Plug your MP3 player into your computer. Open the photo file on your computer and drag pictures into the player. You can create folders to organize the pictures.
Sep 30, 2009 | Coby MP-C552 MP3 Player
How do I recharge Coby MP3 player? I plugged into USB port for over an hour but it stopped playing after about 20 minutes. Do I need to replace the battery or charge it longer or both? Thanks. Claudia
Coby MPC7085 requires a 12 hours charge when used for the first time.
Always use a direct connection to the computer when charging with the USB cable: a hub or cardreader should be self-powered.
See page 12 of the manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Sep 28, 2009 | Coby MP-C7085 MP3 Player
How do I recharge MP3? Do I just plug it into USB port to recharge. Do I need to replace battery after 8 hours of play?
yeah that's pretty much all you gotta do =/ Make sure your computer has it installed and plug it in
16gb Sansa player that recharges and plays for only 3-4 hours
let your battery run out by leaving you mp3 player play as long as it can....then open up the back of the mp3 player take out the battery and put the battery a freezer for an out or 2 then let it sit out for a day then put it back in the sansa and recharge it and it should either fix it or help add more life span to the charge
Jun 21, 2009 | SanDisk Sansa e260 MP3 Player
Coby mpc7095 mp3 player
it dont play my ******* song
Mar 02, 2008 | Coby MP-C7085 MP3 Player
Mpc7085 is fozen
well im only a 12 year old really smart so what u can do is in back on it it says reset press on it and it will unfreeze
Jan 13, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7085 MP3 Player Logo
64 people viewed this question
Top Coby Audio Players & Recorders Experts
Ekse
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
