Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaking
I also am experiencing the same leaking problem with my duet front loader. This problem occurred after we had the bellow replaced. Could the replacement of the bellow have caused the new issued with water coming in from the front left of the washer and leaving a puddle of water inside the washer?
  • 1 more comment
  • med1041 Sep 30, 2007
    The water leaks into the washer and leaves standing water. The water is not on the floor. Is the bellow still the problem?
  • Anonymous Mar 18, 2014
    leaking from under washer on left hand side corner...most recently found another leak on opposite corner?
    how to replace the door bellow on front loader
  • 5,911 Answers
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Posted on Sep 29, 2007
  • Jeff Rockwell
    Jeff Rockwell Sep 30, 2007
    No...this isn't a bellow problem, I'm afraid. If you have water leaking into the wash tub with the unit turned off, it sounds like you have a bad fill valve. Even though the valve is controlled, electrically, it also requires that the diaphragm in the valve is seated properly and that the water pressure is high enough (usually a minimum of 25psi) to keep it seated as well. If you've never had water pressure problems before, I would suspect that the valve may be going bad, or you have sediments keeping the diaphragm from closing properly. You can attempt to clean the valve, but if you're going to remove it, you might as well just replace it. I don't think its a job that you would want to do twice. The valve only costs about $35. If you decide to replace it, let me know. I can give you guidance on how to do it.
    PS I believe this is strictly coincidental that the problem occurred after you had maintenance done on it. The bellow is not located anywhere near the fill valve.
SOURCE:
Installing a bellows gasket onto duet sport whirlpool washer
The following link explains step-by-step how to replace the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you haven't purchased a replacement yet, you can find one at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hw do I replae the washer bellow seal on a whirlpool duet washer
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
Replacement parts (if required) can be purchased at any of the following web sites:
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bellow ##W10111435 whirlpool washer WFW8300SW02.
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet front loader:
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I change the door gasket on a Whirlpool Duet washing machine model WFW8300SW03 I have the new part
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: You can view helpful exploded view diagrams of your washer at searspartsdirect.com for assistance as well.
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Duet washer leaks about a cup of water
If this is a Whirlpool Duet series front loader, the following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow (rubber door seal) begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
Replacement parts can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. Overloading the washer can also contribute to premature wear and tear on the bellow. Always follow the manufacturer's recommendations for proper loading.
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesnt drain properly and leaks waster at the bottom
If this is a Whirlpool Duet, the following link explains what you have to do to determine the source of a leak:
In most cases on a FRONT LOADER, leaks are caused by the rubber door bellow developing small rips or tears due to age and wear. If the bellow is leaking, it must be replaced. The following link explains the steps necessary to do so:
Double check all your drain hoses to ensure they do not have any rips,holes or punctures and all clamps are tight.
Replacement parts (if required) may be purchased on line at any of the following websites:
repairclinic.com
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer leaks. It is not the
The following link explains how to determine where a leak may be coming from in a Whirlpool Duet:
In many cases, the rubber bellow (door seal) is the source of the leak and will need to be replaced. If the bellow is ripped or torn the following link explains step-by-step how to replace one:
NOTE: THe bellow does wear out from time to time and will need to be replaced. However, using too much detergent, the wrong type of detergent, or loading the washer excessively can contribute to premature wear and tear and deterioration.
If you have any questions, or are having problems determining where the source of where your leak may be coming from , please post back and let me know. I hope this helps you.
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door lock error whirlpool duet front loader
DO NOT BYPASS A SWITCH UR HOUSE WILL BE FLOODED INS WILL NOT COVER IT. YOU NEED A DOOR LATCH, AN MMC AN PROB A BELLOWS CAUSE YOU WILL RUIN IT PUTTING THE SPRING CLAMP BACK ON. DO URSELF A FAVOR AN CALL A SERVICE TECH
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
669 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
