Question about Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-z5 won't connect to the PC!
I've had my YP-Z5 for about nine months now, and some time ago it started getting weird. At first, I noticed that my background reseted to the default, blue one every time I restarted the mp3. The clock in the upper-left corner also changed from 24h-format to 12h each time as well. Also, the only way to reach my songs are from "Browse Files" (The Recordings are still there though). I've tried to press the reset button several times, but it won't help any. The worst problem is that the mp3 refuses to connect to my PC! When I plug it with the USB-cord, it says "Connecting..." like usual, but instead of changing to "Connected" it zaps back to the menu where I can listen to music. Every now and then, it makes a new attempt at connecting, but never succeeds. I can still charge it, though. It worked perfectly fine before, and we haven't really done anything with the PC since then. ANY kind of help would be very appreciated!
  • 10 more comments
  • SalmonW Nov 06, 2007
    The same thing happened to me. All fine for over a year and now I can't get at any of the music, or load anything on to it.
    Connecting to the PC brings up the screen but then reverts to the normal user interface. The device is not recognised by my Windows XP machine, I can't update the firmware, nothing.
    I have used the reset button a few times with no effect.
    Any help greatly appreciated!
  • emmylo92 Nov 11, 2007
    I have the same problem as soon as i plug my mp3 into my computer it says its connecting and will still on the sme screen and my xp comptuer doesn't reconise it n says its unknown and i have tryed to reset it but it never works , i have had my mp3 from about september 2007 .I would love to find out how to solve the problem
  • Anonymous Nov 18, 2007
    I'm having the same problems you all are describing. I've only had the player for 11 months. One day it was working, the next day it wasn't. And the computer no longer recognizes it. Samsung was no help, they said to send it back to Amazon where I bought it. Now that I'm doing a bit of research online I see a LOT of people are having these problems. I was going to buy a new one, but now that I see how many people have had problems with theirs, I'm more set on spreading the word to people not to purchase them. I'm through with Samsung.
  • Anonymous Feb 10, 2008
    I have same problem exactly, only i deleted everything off it for christmas and put a load of christmas music on it for the family now that's all that is on there, i guess i'm only using it once a year :-(
  • Tommyzola Mar 01, 2008
    I bought my YP-Z5AB in Feb 07. Now, just over 12 months later (just out of warranty period as usual), it has started malfunctioning. When connected to the pc, it display says "connecting" for a few seconds and then reverts back to the usual interface - it doesn't actually connect to the pc. The pc doesn't recognise the device, so I can't do anything with it. In addition, the music files are now only accessible via the "browse files" function, and the battery isn't recharging.
    I have tried all the following - non of which have helped:
    1) Pressing the reset button.
    2) Switching the device to UMS mode - whereby the pc should recognise it as a removeable harddrive.
    3) Contacting Samsung (whose customer service is some of the worst I've encountered). They advised that I should speak to Amazon (where I purchased it), as they could do nothing for me.
    All in all, this seemed a good product initially, but the fact that it's broken down after a year really isn't acceptable, and Samsung customer service are a disgrace. I would recommend avoiding Samsung products all together.
  • anti-ants Mar 05, 2008
    Ive had my yp-z5 for 10 months. One morning i tried to scroll to get to my music by touching the keypad lightly. Instead of scrolling up one bit when tapping it lightly, it scrolled all the way up which meant i could only open the 'music' menu and the 'now playing' menu. ??
    I decided to reset it and pressed the reset button. Gratefully the keypad worked now but When i tried to connect to my xp it said connecting, then went back to the normal screen!
    Some of the buttons dont work and some of my music (WMA format) Doesnt play, just says 'system error'.
    Considering buying an ipod if i cant get it fixed
  • Niem Jun 12, 2008
    wont connect to the pc
  • seamonkey06 Jun 21, 2008
    Mines is the exact same! I have to go to browser files to get my songs and it just won't connect to my computer! Holding the return button while connecting it doesnt work and i can't find the Z5 update to install! Are there any other solutions? Can someone PLEASE help me!
  • hollows Jul 02, 2008
    I also have the same problem, all my music is in the browser file now, and my computer does not recognise it, I even brought a new data cable thinking that was the problem! Very frustrating, and annoying as this sounds a common fault, just after warranty!! When I go on to version it says system error. I hope someone discovers a cure (buy an ipod!)
  • adamis74 Oct 22, 2008
    Have same problems. Worst thing is, cannot upgrade firmware, as PC doesn't recognise device anyway (even in UMS). Reset doesn't do anything, and when I check for Version in System Info, it displays System Error. Apparently some file inside the YP-Z5 must be corrupted, but how can it be fixed when it's impossible to access the device via pc and the reset button or 'reset settings' option don't have any effect?
  • FIELDX Apr 24, 2009
    mine does all that also-but it WONT CHARGE!
  • Anonymous May 02, 2009
    Same here, nothing works. I tried everything possible and it seems like I can only throw away, though I like my device :(
This might help getting it connected to the computer.
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Posted on Jan 07, 2008
    New Friend:
I had the same problem in about 2 years but today I manage to fix it!!! I phoned around and finally I talked to someone who knew the solution. It it a software problem. He e-mailed me the program I needed.
For it to work i had to start the program, and then the computer started to look for YP-Z5 player.
I also had to reset the player first (stick a needle) in the reset hole.
Then I plugged in the player into USB while holding down the middle button, the square one. then finally my PC recognized my mp3 player!! Then it was only to follow the on screen menus:-)
The program I used is called "YP-Z5 Updater".
And it installed Version 2.43. I then updated to v.2.51.
Posted on Mar 01, 2010
    New Friend:
My roommate gave me his old YP-Z5 and could not get Windows XP to detect it no matter what I tried. I plugged it into a PC running Vista, and it detected it with no problem. Then using Vista I upgraded the player to the latest firmware using the instructions above, and it is now working fine on XP.
Posted on Dec 11, 2009
  • Anonymous Dec 11, 2009
    My roommate gave me his old YP-Z5, and I could not get it to connect to Windows XP no matter what I tried. I plugged it into a PC running Windows Vista and it detected it with no problem. I then used it to upgrade to the latest firmware using the instructions above (except the UMS mode part). Now it is working perfectly with Windows XP. Many thanks Doodles1.
My mp3 yp-z5 says connecting but wont charge what do i do
Posted on Dec 13, 2008
I've got this problem too. Spoken to Samsung and they don't seem to be able to help. UMS mode on or off makes no difference and unable to update firmware as computer is not recognising the device. Think the internal software has given up the ghost. Looks like we got some real problems here!
Posted on Oct 30, 2008
Im holding the return button but nothing is working for me
Posted on Jan 08, 2008
5 Suggested Answers
SOURCE:
SOURCE: other way to sync the yp-z5 withought windows media player
Hi, I recently spoke to the tchnicians from Samsung who put me onto the Samsung website where you can download the Samsung media Player. That also allows you to sync the unit. Thanks
Posted on Apr 25, 2007
SOURCE: Samsung YP-z5 won't connect to the PC!
i had a similiar problem with mine so i sent it back as it was still on guarantee. i recieved a new one and the old fixed one on top . i was relly pleased with this but now my new ones playing up and simply wont go to the menu, it just stays on the samsung logo screen. if yours is still in guaratee time then i would advise for you to send it back. there are quite a few people on the internet who are also experiencing the same problems. there is obviousl something wrong with the technical side of things to do with the mp3.
Posted on Mar 31, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: YP-Z5
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
marked
  • 6487 Answers
First thing you can do here is to reset the unit to its default settings so all settings will be clear and that will help fixing this problem....and also try connecting this unit to a different computer and check if it will be conencted fine because if it will stay connected to you can update of flash the software for this ....
Posted on Oct 14, 2008
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
Oct 23, 2011 | Samsung YP-Z5 MP3 Player
Oct 14, 2008 | Samsung YP-Z5 MP3 Player
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
Nov 29, 2009 | Samsung YPZ5FZB 1 GB, BLACK, MP3 Player,...
Samsung YP-Z5
Vista = not compatible with this player
Apr 18, 2008 | Samsung YP-K3 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Connection to my computer
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
oh i think i might know the solution
connect something else like a usb disk to ur computer when it does go to the right bottom corner of the screen where the time shows. then u should see a green arrow on something black icon. double click. that thing shows that ur usb is connected then connect ur mp3 to the computer it should work...but it might not
if u hear that ring noise as soon as u connect that mp3 to the computer u are safe but u have to try other things...
Sep 29, 2007 | Samsung Yepp YP-Z5QB MP3 Player
Open Questions:
Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player Logo
2,820 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
