How can I use saved printmaster projects listed as SIG file on Printmaster 2019?
It may be possible. First, create a new project on Printmaster 2019 and save it. There's no need to actually print it, just save it. Go to the folder where you saved the new project and look at the file type. Is it a SIG file? If so, you may import (or copy and paste) your older saved projects into the same folder as the new saved project. Then the older projects can be opened in Printmaster 2019.
If the new project file type is not SIG then note what type it is. Next, make a copy of the older saved projects folder. Open the copied folder. Left-click to highlight a project, then right-click on it and select "Rename". Keep the same project name, but change the file type from SIG to the new file type used in Printmaster 2019. Next, try opening that renamed project with Printmaster 2019. If the old renamed project is compatible with Printmaster 2019 it will open, ready to use. If it does not open ready to use then your only hope is to contact Printmaster tech support (probably by email) and ask if there's a fix to make older projects compatible.
