Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Xp sp2 who to created system folder our name.
    Problem Solver:
  • 6 Answers
Please explain your problem in details
Posted on Sep 30, 2007
I want two inboxs in outlook express 6
You cannot have 2 folders / inboxes with same name. But you can have may inbox folders if you want. Just give them different names. You can also create rules to automatically sort new mail into different inbox folders. The new inbox is created as a subfolder of yor current position. File, New, Folder Give it a name If you are already in the INBOX, new one will be a sub folder.
Mar 04, 2011 | Microsoft Windows XP Professional
How to fix error 105 on xp while installing a new programme?
This is a Windows Error, indicating that there is no Temp directory/Files.
Please check if c:\windows\temp folder exists if not create it...
May 04, 2010 | Microsoft Windows XP Professional SP2
Problem creating and renaming folders in windows explorer. When ever I try to create a new folder within windows explorer no change occurs. no new folder appears. I have to go back one level then back to...
This issue has been resolved with Service Pack 2 for Windows XP. Here is a link to the Microsoft KB on a walkthrough on how to resolve the issue.
I would also suggest to make sure your computer is up to date with all Microsoft patches by going to here.
Dec 18, 2009 | Microsoft Windows XP Professional SP2
Service packs not cleaning up properly
(sited from http://www.winxptutor.com/randomfolders.htm)
When you install Windows XP SP1, SP1a or SP2, this temporary folder is created on the volume that has the most free space. The folder name contains random characters, and is not always created on the same volume as the Windows folder. For example, this temporary folder may have the following random names:
9470bb12e8a4f3447657236478e41c5
or similar.
352b81d1c4bf3810e28482d9979
This folder is automatically deleted by Windows XP after you install the service pack. However, if the folder is not automatically deleted by Windows XP, you can safely delete this folder.
Please Note:
In most cases, you will receive an Access denied message while accessing or deleting this folder. First, you'll need to Take Ownership of the folder and then delete it safely.
May 21, 2009 | Microsoft Windows XP Professional With...
My computer Desktop is not running.
Hi hichris_4u
You should be able to replace the Explorer.exe. Type in the command prompt expand C:\I386\explorer.ex_ %systemroot%\explorer.exe This will expand a new copy to the windows directory.
You should also download a new version of SP2 and reinstall it. You also could download a clean copy of SP2 Click the Download button. The file is 266MB. Create a folder on the C:\ root called SP2 and download it there. Create another folder called SP2 files now at a command prompt type C:\SP2\WindowsXP-KB835935-SP2-ENU.exe /x it’ll ask you to specify an directory so point it to the SP2 Files folder and let it extract there. Now type in the command prompt expand C:\SP2 Files\I386\explorer.ex_ %systemroot%\explorer.exe to expand a new copy to the windows directory.
If you get an error on destination, try expand C:\SP2 Files\I386\explorer.ex_ c:\windows\explorer.exe
If you expanding fron the I386 from the C:\ root try expand C:\I386\explorer.ex_ c:\windows\explorer.exe
If all fails, try and download SP2 onto another machine and then burn it to a CD for install.
Good Luck,
Mark
Mar 26, 2009 | Microsoft Windows XP Professional SP2
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip  Code:  Code:  http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
Playlist on MP3 player
I would not use the sync. I would make a new folder for your choices and put them in the order you want to hear them. Name the folders according to country, hip-hop, rap etc. If you want put the cd into it's own folder. Name the folder the cds shortened name...
May 27, 2008 | Coby MP-C741 MP3 Player
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
