Question about Brother MFC 420CN All-In-One InkJet Printer
Scanner quit working
I have a printer/scanner/fax machine. It's about 2 years old. The printer works, the fax hasn't been installed, the printer use to work but has decided not to anymore. I have done the turn off unplug restart turn on replug thing, but that didn't work. Any other suggestions to help me? Thanks threedogs
  • 832 Answers
The scanner works with the windows built in driver. Uninstall the hole mfc suite and reinstall after restart. This is the fix for the software. You can check the hardware simply by copying a page. If you can copy there is no hardware prob. Post here again if it does not work and let me know your windows version, too, please.
Posted on Sep 29, 2007
SOURCE:
Printer disposal
Do not worry about printer storing any personal data of yours. HP Printers do not have any data stored except for # of pages and Ink Level. However if you have setup fax and If you had setup Speed Dial List, you need to wipe the # in the list.
To do this, Disconnect the power cord from back of printer. Press and Hold # and 6 button while connecting the power cord and release the buttons after 2-3 seconds.
This will erase all the data from the Printer
Regards,
Sean
Apr 22, 2013 | HP Office Equipment & Supplies
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
Unable to scan or fax. I have a HP Officejet 6110 all-in-one printer, copyer, scanner and fax machine. I have never used the scanner and the fax simply stopped working after years of service. The printer...
Thanx for contacting in fixya....
u need to uninstall the printer software and then reinstall if this problem persists again format ur system c driver it is the only sure solution
regards
john symester
Nov 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X5340 - All in One Printer/Scanner/Copier/Fax
Please follow the steps given below to add the scanner using Scanner and Camera wizard.
1. Plug your scanner into your computer.
2. If your scanner is "Plug and Play," the "Scanner and Camera Wizard" starts or double-click add device. Follow the instructions on your screen.
Note:
1. To open "Scanners and Cameras," click "Start," click "Control Panel," click "Printers and Other Hardware" and then click "Scanners and Cameras."
2. If you have a "Plug and Play" scanner, Windows detects it and installs it automatically.
3. If your scanner is not "Plug and Play," follow the installation instructions that came with the device.
4. If your scanner is not listed in the "Scanner and Camera Installation Wizard," try to install it using device manager.
5. After you install your scanner, you can test it.
Oct 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
I bought the Intellifax 2480C. I just tried to install the software It installed printer driversI cannot use scanner I try to install disk 1 in the downloaded stuff I get "An error occured during the...
Use the software that came with the machine. A fax machine will appear as a printer in your printer folder. To get the scanner to work, you can use most software that you probably already have installed on your machine i.e. MS Works, Word, MS Paint, Corel by using the IMPORT from camera or scanner function on the software and choosing your Brother machine as the source.
Jun 27, 2009 | Brother IntelliFax-2480C Fax
Lexmark series x2350 all in one scanner does not work.
Is the scanner driver installed ?. You can check this by unplugging the USB cable from the back of the printer and connecting it again. If you get any Plug and Play prompts on the computer, install the driver by pointing it to the correct scan driver location.
May 27, 2009 | Lexmark X2350 All-In-One InkJet Printer
Scanner quit working on Dell AIO962
Apni ma mt chuudvao mujh se philips walo
Apr 29, 2009 | Dell 924 All-in-One InkJet Printer
My scanner just quit
Need scanning software installed, go to brother web site and find full software and driver download package for your printer (under drivers) and install as instructed by program, you should unistall old driver setup first if enconting problems with new install, there is a uninstall on brother web site too
Oct 19, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
70 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
