Question about Lexmark P6350 All-In-One InkJet Printer
Carrier jam i am unable to my printer at all because i have a carrier jam please can someone tell me how i might fix this or do i need to take it to an expert?!?
    Problem Solver:
  • 18 Answers
Hi, Open the Top cover so u can see the cart carrier. There should be a thin translucent tape. If its snapped out then ur printer is defective. If the tape is still present in the printer and attached from left to right, then make that strip pass "behined the cart carrier, in a small slit". Then u wont have cart carrier jam. If it still persists then printer is defective.
Posted on Sep 29, 2007
Also make sure that there is no obstruction on the left hand side inside the printer
Posted on Oct 29, 2007
  • Jane Sep 23, 2013
    no obstructions...
SOURCE:
Paper Jam in my Lexmark 5600/6600 printer. When I look for the jam, there is no jam.
Type in the search engine on your computer How to fix Lexmark 5600/6600 printer paper jam. That should tell you.
Jun 09, 2017 | Lexmark Office Equipment & Supplies
Carrier Jam
Please provide the model and the make
Apr 12, 2008 | Dell 924 All-in-One InkJet Printer
What's a Carrier jam?
Carrier Jam means that the Carrier which carries the cartridges is not moving correctly in this case please follow the below Steps:
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
May 07, 2013 | Lexmark 3-Pack Axis 5400 Print Server .:...
Carrier jam on lexmark x5070 how do I fix it or clear it?
We apologize for the inconvenience. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover to access the cartridge area. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  2. Remove both cartridges from the printer.
  3. Check the cartridge area and make sure encoder strip is not loose. The encoder strip is transparent strip located behind the cartridge carrier along with the carrier belt.
  4. If encoder strip is properly seated in the printer, close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, re-insert one cartridge first. Close the printer cover and check for any errors. The carrier jam could be due to one of the cartridges.
  7. If no error appears, re-insert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, try to print again to verify that the carrier jam issue is fixed.
We hope this information has been helpful.
Oct 11, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
HOW DO I FIX WHEN IT SAY CARRIER IS JAM
the link below will give you precise answers to carrier jam,, please read carefully and follow instructions how to adjust and free up jam area
http://www.lexmark.com/publications/pdfs/3400/eng/ug.pdf
Oct 31, 2010 | Lexmark X3470 All-In-One InkJet Printer
Deskjet F380 printer unable to print claims paper jammed cheched printer no paper jammed all other ptinter functions ok
Hi
Seems to be problem in sensors for that you need to open the printer and clean the sensor, If you are not expert in that then please check service centres for servicing.
Boopathy.T
Aug 17, 2008 | HP Office Equipment & Supplies
Need to fix a carrier jam
you have to open the printer and check for any parts is struck or dislodge
Jun 23, 2008 | Dell 924 All-in-One InkJet Printer
Brother LC-51 unable to clean code 4F
The code 4F unable to clean comes up for paper jam, if no paper jam,TRY THIS MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Hope this may help;
Regards,
VOTIT
Jun 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Clear carrier jam
There are few things you may try to fix the above problem.
Rebrick the printer. and set the printer to factory defaults
Apr 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark P6350 All-In-One InkJet Printer Logo
222 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
