Question about Philips Magnavox TP3285C 32" TV
Tv burn out
I have a philips tv and it turns on but no picture i think it burn out
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It might be due to high voltage in tv. you must have smell like burning. do not worry it happens so many times due to failure of transistor or fly back transformer.or some capacitor gets shorted. call skilled tech to fix it it is not a major problem. you may see fuse blown or has become black but do not try to replace it as it has blown due to something is short.unless you are a tech person as tv is chrged thiogh it is off. hope this will help. good luck.
Posted on Sep 30, 2007
SOURCE:
The picture turned darker and now there are shadows from previous pictures or CC or station graphics. Is the TV going out or is there a reset
The tv has a problem in video section or IFsection the shadows means that the lcd is burned from excees voltage.your tv screen will need to be changed its damage.the video section and IF section of your tv is in a IC package its not hard to identify.good luck.
Sep 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
Tik tik sund from philips tv
when i turn on my philips 20 in flat tv i have no picture, just black screen with a tik tik sound
May 11, 2010 | Philips Magnavox 27MS343S 27" TV
I have a 50'' Philips tv. When I turn it on the picture comes on fine, within a matter of minutes the picture goes out and this red light comes on highlighting a tiny picture of a light bulb on the ''on...
Sounds like your lamp is bad. I think this is the set where you have to take the whole back off to replace the lamp. Once you take the back off, its on the left hand side.
Dec 02, 2009 | Philips 50PL9126D/37B 50" DLP TV
No picture in Philips 42pf7220a/37 Plasma TV.
Hi my name is Roety,
I can help you with your issue ,
You can look for two bad capacitors on the power supply. They will look swollen on top like this photo
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 14, 2009 | Philips 42PF7220A 42 in. Plasma Television
I've got a Philips 50P8341A Projection 50'' TV. My problem started with the screen only showing an orange image. The picture was clear and sharp, but there was no color other than orange. So I tried to fix...
Turn the top left knob down till the pic comes back and the reason your color is off is the fluids in the green and blue chambers needs to be changed.
Nov 12, 2009 | Philips Televison & Video
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
Philips 19pr14c225 19" tv NO Power
maam i think theres something wrong with its power supply,,kindly check it out thankss and hope to help you!!
Aug 21, 2007 | Philips 20PT6441 20" TV
Only sound, no picture
turn the AC power off and on again, this worked several times
Jul 05, 2007 | Philips E-box FTR9964 Video Capture
TV WILL NOT COME ON
You might have a relay with bad contacts OR a loose or burned loose resistor in the power supply circuit. Stargazer
Mar 03, 2007 | Philips 32PT8302 32" TV
Philips Magnavox TP3285C 32" TV Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
