Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain may be plugged
After doing a load of rugs and adding some oxyclean, wich seems to have created a lot of bubbles, ( we did try the rinse and spin cycle) how ever the washer won't drain and now water is leeking out of the bottom of the machein. It seems to be plugged up or something. Please help me know how to unpuge it I am not sure how to take off the hose or what ever is necessary
  • meteoro Mar 14, 2008
    My washer is not a calypso but is a top loader. I think my Whirlpool (model lsr8433kq0) was made in 2001 (when I bought it). The original timer went bad, got a new one, installed it and I can't get it to start @ the drain-spin cycle (is full of water). I can only start it at the begining of each full cycle, it shakes but when it comes time to drain it doesn't. I checked and re checked part number and it checks ok (I got it from repair clinic.com). Help is needed big time, can afford to go another weekend without it.
    Many thanks in advance for the help.
    Meteoro.
  • 363 Answers
The drain may be clogged with debris. Please check your manual because there may be an access port under the panel at the bottom of the machine to remove the blockage.
Posted on Sep 29, 2007
  • Martin B
    Martin B Sep 29, 2007
    Remember if I am correct and there is a lot of water backed up then you should take precautions for a mini tidal wave.
    Regards
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
not draining quick enough, therefore spins with too much water throwing it self off bal. ever have any problem with this machine. heres what i can suggest. tip the machine back and remove 3 5/16 screws holding bottom panel on . on the right side approx 2/3 of the way back is the pump assy.( a yellow and black hose going to pump. are there clips on the pump holding it up to the pump motor???if so yuou can release the clips and disconnect the hoses looking for lint build up in pump itself.WARNING!!! you will ge wet ther is ALWAYS water inside this pump especially if you not pumping out correctly.i use a large black trash bag under to catch water.sounds like a clogged drain pump. they have a replacement for this particular pump. it comes as 1peice now pump and motor, bigger ports to prevent lint build up, easy enough to replace if needed. sounds like a clog fro sure though good luck
Mar 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Dishwasher fills with soapy bubbles that do not seem to darin away
The Sink is siphoning into the dishwasher. Where it connects to the sink pipe make sure the tube loops up after it leavs the sink so it cannot drain down into the dishwasher when the sink is in use.
Mar 11, 2012 | Whirlpool Dishwashers
The spinning thing won't spin all of a sudden. The washer is making a lot of noise and will drain but won't spin. How do you take the back off?
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 07, 2011 | Whirlpool LSN2000LW Washer
The door on my Maytag MAH2400 will not unlock. I have tried shutting off power to no avail. There is a throw rug in the washer that looks like it is caught in the door. Is there a manual release that...
Sorry no theres not,And when you get the throw rug out do not put these in there they do a lot of damage they can clog the pump.First thing try pushing the start button agin you well have to do this several times the machine has to drain before the door opens,when it open up.put draino-max and let it stand for 1-2hrs and run machine no clothes.And no more throw rugs
Jul 04, 2010 | Maytag MAH2400A Front Load Washer
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin a lot of water out of rugs.
does it even spin? check for broken coupler by checking for tub movment when opening lid when you hear motor in spin. if good check that machine advances to spin from neutral drain automatically. let it enter spin from rinse on its own. first it will drain without spin. after 2-3 min of drain motor will pause (with clank) then restart in spin. This pause can be accomplished by opening lid and closing as well but the timer should do it on its own. if bad replace timer.
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Jul 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Energy Washer front load - about 5 - 7 years old
Hi mommo2,
I really hate those little rubber pieces that come off of those rugs, they really gum up everything. Just for future reference try to wash those outside with a water hose and a scrub brush. It will save you lots of money in repairs.
As for your current problem try to get as much out of the tub as possible. Then you will have to remove the small kickplate on the bottom of the washer. Get you some towels and a maybe a flat pan to catch some water. The panel will have a few screws around it that will need to be removed. Once you have removed the panel you will see your pump. The front of the pump has a filter that can be unscrewed and removed for cleaning. Unscrew the filter and get ready to catch some water. Maybe as much as a couple gallons. Once you have cleaned it out put the filter back in the pump and leave the panel off. Run the washer throught another cycle and clean the pump out again. You may need to repeat this several times. Hopefully this will solve the problem, if you still have draing issues you could have a clogged drain and for that you may need a plumber. Well good luck to you and I hope I helped. Mike Anderson mca0824@aol.com
May 02, 2008 | Kenmore 43142 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
63 people viewed this question
Sal De
Marvin
Marvin
jimorris77
