Question about Whirlpool MH1141XM Microwave Oven
MH1170XSB-0 DOES NOT HEAT FOOD
  • Anonymous Aug 19, 2008
    All a sudden doesn't heat food any more.
  • dspaul4 Dec 17, 2008
    Everything appears to be working as normal however it generates no heat and this started yesterday when took 5 minutes to melt a stick of butter at 50% power and then later took 8 minutes to pop some of the corn in a microwave popcorn bag. Then after that the unit stopped heating all together. Any suggestions?
    Scott
  • Whirlpool Master
  • 9,149 Answers
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 05, 2007
2 Suggested Answers
  • 9 Answers
SOURCE: my whirlpool microwave model# MH1170XSB-0 does not
Try to tighten the screws on the inside i did and it works
Posted on Jan 13, 2010
Whirlpool mh1170XSB-0
Inside the oven. There are usually 3 fuses. 2 are on the board, while one is on a wire enclosed in a plastic twist to open capsule. The fuses in a microwave oven is a little bit specialized. Be sure to get the proper replacement part.
Mar 16, 2014 | Microwave Ovens
Whirlpool microwave surface light does not work despite replacing the bulbs. I suspect that a previous renter's cat was fascinated w the on /off switch and burned it out. The light switch operates and the...
I am suspecting that your microwave has cheap chinese relays inside and instead of plating the part where electricity goes through with a high temperature metal that is a thick enough coating they used a cheaper metal. When they do that a relay arcs an spot welds itself open or closed. A strong tap on the control board (once taken apart) will release it. I advise to have a look at the control board for overheating, or burnt circuit board traces as well.
Nov 09, 2013 | Frigidaire Microwave Ovens
The microwave will not heat food. It will turn on the turntable will go around and the time will count down but the food is not heated when done. tried different heat setting with no results.
This seems to be a common problem, there are three parts that will cause this, the magnetron "heats food" a common failure, the high voltage diode and capacitor are the other two culprits. The cost to repair will approach the price of a new oven.
Feb 01, 2011 | Samsung SMH9151 Microwave Oven
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Space maker JVM1440WH01 sounds like it is heating, turntable turns light works, but food does not heat???
heatman101
0'''''''''''''
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating any food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-0=-0
May 10, 2010 | Maytag MMV4205 Microwave Oven
My whirlpool microwave MH1170xST-0 works except it does not heat the food
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Apr 06, 2010 | Whirlpool MH1170XS Microwave Oven
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Aug 18, 2009 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool MH1141XM Microwave Oven Logo
567 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
