Question about Compaq Presario 5000 PC Desktop
Monitor display not coming after some minutes
If i switched on my pc, for the first 5 minutes it is working normally as usual. but after that, some grains like in tv , it appears. after that some fluctuations occurs with the colour black and white images.then, the whole display disappears. no problem in video ,or power. i have checked that by replacing with my friend's monitor , it is working as normal. so , wat my thought is the problem is with the monitor , or data cable or inside the circuit .... i m sure that it is not with the cpu
    Sergeant:
  • 457 Answers
No it is your monitor after all you used your another monitor and all was well. For what its worth get another monitor. NOTHING ELSE IS WRONG!!!
Posted on Sep 29, 2007
SOURCE:
Wen i conect my compuer only de power light comes on.day before i working normal and i switch off normal.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Toshiba Satellite 1805-S204 Notebook
Monitor color is pink at switch on. 5-10 minutes after normal
There are many things that could be causing that, but to fix it would take some electronic equipment, schematic, and know-how. It could be as simple as a faulty potentiomet, but a shop would charge you more than it's worth to fix it. My advice is to live with it until it gets too bad, and invest in a new one If you're not ready to advance to the LCD monitors yet, check with a Used Computer Store- they usually have CRT monitors at a reasonable price. Hope this helps.
Mar 25, 2010 | SAMTRON 55V 15" CRT Monitor
NO SIGNAL PROBLEM
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
Jun 02, 2009 | ASUS VW192S Monitor
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
My cpu is not coming on
Is the power button orange, it's most likely a motherboard failure.
Nov 11, 2008 | Dell Dimension 2400 PC Desktop
Samsung 192N suspect power supply problem
I'm sure it is power board failure that need repiar or replaced the defectieve parts of your LCD .
Apr 18, 2008 | Samsung Syncmaster 192N 19" LCD Monitor
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Dec 09, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
Compaq Presario 5000 PC Desktop Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
