Question about iLO DVDR05 DVD Recorder
Dvd player turns on and that's it
I have a ilo dvd player/recorder and have never been able to get it to work with any tv. I have connected it through a vcr and directly to the tv, still nothing. Can't set it up or play dvds. It says its playing, but nothing on tv. Help please.
  • msqria Nov 21, 2007
    same as listed
I have ILO dvd ro5/zu Burner walmart cheapy and I read Capacitors for power supply go bad and leak there are 2 (fuhjyyu 2200uf 10volt) also it runs very very hot so I put in an old computer fan to cool it down works great now, problems with clock flashing and humming noise while recording and playing back. It still has a little hum but other than that it works great 3-4 years old over 150 dvd's burned.
Posted on Mar 02, 2008
SOURCE:
AvioriX
  • 689 Answers
SOURCE: DVDs won't play or record;
have you checked if region code matches?
Also please let me know the exact model of your DVD Player
Posted on Mar 05, 2008
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
Nova_1
  • 196 Answers
SOURCE: can't play recorded dvds on other dvd players
are you finalizing the discs after recording? some recorders do this automaticaly others have it as an option you have to select.. without finalization they will play on your own recorder but not on other machines.
Posted on Oct 07, 2008
JTC13
  • 17 Answers
SOURCE: PLAY REGION 2 DVDS ON DVD RECORDER
Press "Setup"
Go to "Lock"
Press 0 seven times.
Press "Return"
Posted on Feb 19, 2009
SOURCE: My Sony RDR-VX530 VCR/DVD player/recorder just stops playing
play a lens cleaner cd in it,,, it will work smoothly
Posted on Apr 21, 2010
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
How do i play a dvd movie in ilo dvdr05 dvd recorder
You may have to connect to a different output until you can change the settings back.
Dec 03, 2014 | iLO DVDR05 DVD Recorder
I have a iLO DVD recorder,it will turn on and show menu on front of unit but I can't get the menu to come on screen of TV.It is model #DVDR05/ZU.. You put a DVD into unit and push play on remote and it...
I have a DVDRo4 model so they may not be the same. I connect 3 wire RCA cables to the DVDR output and to TV 3wire RCA input. I set the TV chan to Aux. I set the DVDR souce button to disc. Hope this works on you unit 05
Nov 22, 2009 | iLO DVDR05 DVD Recorder
I have an ilo dvdr04 recorder. ihave set it to my tv which works ok. yet when I try to play or record a dvd nothing comes up, and the tv stays on. how do I get the dvd to come on?
Push the source button on ilo Remote.The front RCA plugs AV1 the rear is AV2 of ilo.
If you still don't see dvd you are not wired correctly.
Jun 18, 2009 | iLO DVDR05 DVD Recorder
ILO DVDR05 RECORDER
I saw a device that hooks to the computer that allows you to input media from a player (VCR or DVD) to the computer but nothing that works the other way around. What is it you're trying to do?
Oct 22, 2008 | iLO DVDR05 DVD Recorder
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Can't record from tv or disc,
shouldn't need one, If you can't get the tuner source of your ilo to record, try using A/V cables (output) from tv to (Inputs) on ilo. set tv on channel you want to watch and it should come through to the ilo (selecting the correct source input of course) If your tv is really old and doesn't have A/V then you will need RF Modulator. This way of hooking tv up will also work with recording DIGITAL signal from a Digital converter box type tuner (the tuner in Ilo soon to be no longer operatable).
Mar 30, 2008 | iLO DVDR05 DVD Recorder
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
95 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
