Question about Gateway MX3215 Notebook
Memory Problems for a Gateway Mx3215 Laptop
I have been have problems upgrading my memory for a Gateway Mx3215 laptop. I bought some memory at Best buy for it and installed it and the laptop didnt even boot up, black screen. I bought memory from Gateway online and put it in and it gave me a black screen. I was wondering if anyone has this computer and has upgraded the memory successfully. Thanks
  • 17 more comments
  • batte Nov 26, 2007
    I've got the same problem. Specs say I should be able to upgrade from 256 to 1gig of memory. I've bought one-gig sticks from Gateway, Memorystore.com, and Fryes -- all give me the same black screen.
    Should I try a 512m stick?? That's a bummer, only one slot.
  • Anonymous Dec 31, 2007
    I also have the same problem. Purchased a private label 1GB 200-pin SO-DIMM PC5300/4200 DDR2 667/533 that is supposed to be able to run either way (or so the guy at the store told me). Did I get taken for a fool?
    Thanks,
    Chris
  • Workmen Jan 05, 2008
    I've got the same problem. Specs say I should be able to upgrade from 256 to 1gig of memory. I've bought one-gig sticks from Arch, Memory and it give me the same black screen. I place the old memory back in the notebook and all I get is a black screen. is there a fix some how.
  • El Tee May 21, 2008
    These machines do not run at 633. So, even if you get the DDR/DDR2 problem sorted out (read the label on your existing card) you can get black screen nada working results - Gateway will diss you for not going thru them and then charge you for assistance. I'll never deal with them again..but if you order a gig...make sure the supplier knows it is for the 597 or whatever Mhz speed.
  • Donita Price Aug 04, 2008
    Got the same problem. Gateway is NO help at all. Keep directing me to TigerDirect.com. Have tried 3 different memory cards....Best Buy has tried to install them all with no luck. Gateway said to buy Gateway Memory. Does this make sense? No one knows what "Gateway Memory" is. Please someone help.
  • Anonymous Oct 13, 2008
    i also have the mx3215 with the vn800 chipset upgraded to 1GB DDR2
    533Mhz PC2-4200 and it only reads 512mb from wich 64mb are subtracted
    for the video card to use. anyone has an idea as of to why its only
    using half of the ram???
  • Anonymous Jan 08, 2009
    CRUCIAL CT908350 BLANK SCREEN
    http://www.via.com.tw/en/products/chipse...
    SHOWS WHAT THE CHIPSET INFO
  • GatewayHata Jan 09, 2009
    I bought a 1GB Stick from Crucial. The correct Memory was verified by a Crucial technician. However, after installation, I could not get the laptop to post.
  • PC Charlie Jan 13, 2009
    I have a MX3215 Notebook. It came loaded with 256M (Hynix PC2-4200). I tried a 512M (Hynix PC2-5300) taken out of another Gateway Notebook and my system will not boot with the 512M.
    I also tried a PNY 1G PC2-5300 and a PNY 1G PC2-4200 with no luck.
    I have a MX3215 Notebook. It came loaded with 256M (Hynix PC2-4200). I tried a 512M (Hynix PC2-5300) taken out of another Gateway Notebook. However my system will not boot with the 512M.
    I also tried two different PNY 1G's (PC2-4200 and PC2-5300) and my machine still will not boot.
  • Anonymous Jan 22, 2009
    SAME PROBLEM
  • Anonymous Feb 11, 2009
    Same problem. Has anyone found the solutions yet.
  • pmcozzi199 Feb 11, 2009
    Same problem. Has anyone figured out the solution yet.
  • Anonymous Feb 17, 2009
    Just dropped in my 1gb chip from Crucial. Black screen. Not good.
  • INDAGAN Apr 06, 2009
    i also have the mx3215 with the vn800 chipset upgraded to 1GB DDR2 533Mhz PC2-4200 and it only reads 512mb from wich 64mb are subtracted for the video card to use. anyone has an idea as of to why its only using half of the ram?
  • usafdale5 Apr 27, 2009
    I installed the 1GB from Corsair and the computer runs fine, it just will not recognize the new ram
  • El Diablo 1 May 15, 2009
    I have the same issue I was told my mx3215 could hold at least 1 GIG
  • dave676 May 11, 2010
    I to have a Gateway MX3215 laptop. I tried two different 1GB crucial PC2-4200 DDR2 chips. The laptop would not boot up. Then I tried a Kingston chip. The laptop booted up but only recognized 512MB. Someone said to try a Kingston 1GB number KVR533D2S4. It worked for them. I tried it and it also only recognized 512MB, both in bios and Windows XP. I have never seen this with any other computer before. Has anyone contacted Gateway to see what they have to say, or are they clueless also.
  • Anonymous Mar 19, 2014
    I was wondering if there are any home remedys or any inexpensive way to keep the laptops shell clean without having to buy expensive store bought products?
There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
Posted on Dec 18, 2007
  • Patrick Dec 20, 2012
    WRONG! The PC2700 memory you recommend is physically configured different and will not even fit, even though my MX3215 does have the VN800 Chipset. Have also tried a DDR2 PC4200 chip from Crucial that won't work. Between the squirrly product Gateway put out, and the bogus posts like this I have found while troubleshooting, I'm about ready to frisbie this laptop across the yard.
I have the MX3215. I installed the following memory card and it works:
Corsair Value Select VS1GSDS533D2
960 MB shows up under Control Panel/System. 64 MB is used for the vidieo card.
Posted on Dec 16, 2008
    Sergeant:
  • 457 Answers
I did a google search about your machine and the Ram associated to your machine is this. 256 MB 533 MHZ DDR2 SODIMM Memory Module What you may have bought was some cheapie the person wanted to quickly sellyou. This picture is the standard in your machine and extra exactly would double your memory ie;512MB
Posted on Sep 29, 2007
    New Friend:
I had the same problem a few years ago. I bought RAM and didn't work so when to best buy to return it and the computer guy said the this computer had mother board that gateway bought from HP or Dell I can't remember. But only gateway RAM will work. I bought the RAM from gateway website. It worked great no problems for 3 years now. MX3215 this should fix your problem
Posted on Jul 27, 2010
Well as a tech i have noticed that lapp tops are very picky about the ram so my recomendation is that you should test any ram you can before you buy but if you cant get exactly what the specs say if you dont the system has a smaller chance of working
Posted on Jan 03, 2008
    New Friend:
I've been dealing with this for months. Every time I tried to upgrade my MX3215 from 256MB to 1GB, it wouldn't boot up. I reinstalled the factory 256MB and it worked. The factory memory module is a PC4300 DDR2, so I assumed I had the NVIDIA chipset. I shouldn't have assumed that. I ran the SIW software program and it showed that I actually had the Via VN800 chipset. I can only guess that the factory did some tweaking to get the factory module to work. I'm ordering a 1GB PC2700 module and will see if it works. I'll let you know!
Posted on Jun 27, 2010
    New Friend:
You must buy the memory that has (PC-4200). It cannot say compatible with or looks likes or acts like...I found a Centon 1GB PC-4200 DDR2 and it worked on first installation. I tried the kingston ddr2 but it was a PC5300 as well as a crucial PC5300..they both did not work on my MX3215.
Posted on Apr 12, 2010
I also have the mx3215 with the vn800 chipset upgraded to 1GB DDR2 533Mhz PC2-4200 and it only reads 512mb from wich 64mb are subtracted for the video card to use. anyone has an idea as of to why its only using half of the ram???
Posted on Oct 13, 2008
Confirmed... kingston memory gives black screen, no post.
Model Laptop: mx3228
Memory: kingston kvr667d2so/1gr
what a joke...
Posted on Aug 19, 2008
Brought 1 gb memory for my mx3215 from crucial.com works great if any help 1GB 200PIN DDR2 SODIMM 128MX64 PC2-4200
Posted on Aug 17, 2008
I have a gig of kingston installed in mine and it works fine. i didn't install it though. it shows as 960K
Posted on Jun 15, 2008
I have one of these as well. i too went to tigerdirect for memory, and got the black screen and then to best buy for the same results. finally i broke down and bought a 1gb chip gateway. i installed it, and the machine booted right up! one problem, though...
... the bios only sees 512 mb! god i hate gateways. but i figured i'd post this, so others will be able to upgrade their laptops as well. i'll post again when i work out the 512mb / 1 gb issue.
Posted on May 08, 2008
I have the VIA and idk how but my dad got my 1gb memory upgrade to work
Posted on Mar 20, 2008
Not gonna work. Unfortunately mx3215 has just one memory slot
Posted on Nov 06, 2007
SOURCE:
Can Gateway MX3215 boot to usb stick?
If you go into the BIOS configuration then the Device boot order and you do not see the USB port in the list, then an USB boot up option is not available.
If it is available the move the USB as the first boot device so you can boot up with an USB memory stick.
Nov 13, 2011 | Gateway MX3215 Notebook
Cannot upgrade memory on my Gateway MX3215
Use Corsair Value Select VS1GSDS533D2.
Aug 17, 2009 | Gateway MX3215 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Trying to upgrade memory, have tried three sticks purchased at Best Buy terrific Geek Squad. None work. Where can I purchase a upgrade memory?
You may have non OEM memory, your system may not be able to handle that much mem, or you could have something wrong with the connector that your mem fits into. If your original mem still works then the connector is not the issue. You should also make sure you are putting in the memory stick correctly. Make sure it is put in straight and is firmly placed in the connector. If you don't it will cause your problem. Capacity is 1G. If you are trying to put in a 2G it will not work. Hope this helps.
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=61473
Try this site. They say if it doesn't work you get your money back.
Feb 07, 2010 | Gateway MX3215 Notebook
MX3215 UPGRADE PROBLEM
When memory upgrades don't work, the problem could be incapable memory between RAM modules.
Try to use RAM from the same manufacturer, especially the manufacturer of the RAM that was working in the laptop.
Use RAM that have the same bus speed specification.
Jul 20, 2009 | Gateway MX3215 Notebook
Memory upgrade not working
It only Accepts two PC–2100 SDRAM memory modules..If both are same then the slot might have some problem...
Jan 29, 2009 | Gateway 450ROG Notebook
Gateway MX3215 will not come on its only 2 years old
check first to remove the battery and plug the cord if it is working without battery...if working..means the battery problem...
try to put the battery back into laptop and check if working and not working.
Jan 04, 2009 | Gateway MX3215 Notebook
Memory on mx-3215
No, the maximum you can get for this laptop is a 1GB chip. When buying it, make sure its DDR2 SODIMM PC4300. The ram below the yellow box is what's compatible (its about $25 for a 1gb chip anywhere you look)
http://www.ramseeker.com/ram/PC5300_DDR2_SODIMM/
Jun 08, 2008 | Gateway MX3215 Notebook
Mx3215 memory upgrading problem.
Here is a link for you open this page and enter your serial no.
Click Here
This page will tell you which one is campatable with your system.
Thanks
Iqbal
Mar 17, 2008 | Gateway MX3215 Notebook
Open Questions:
CONTACT AOL EMAIL CUSTOMER CARE 18OO8O31O69 There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 22, 2019 | AOL Computers & Internet
PHONE NUMBER 18OO8O31O69 FOR AOL CUSTOMER SUPPORT There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
HOW DO I CHANGE MY AOL PASSWORD 18OO8O31O69 There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
See all Gateway MX3215 Notebook Questions
Gateway MX3215 Notebook Logo
4,535 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
