Question about Palm TX Handheld
How to connect my palm to my computer when I am using a reseault Linksys
I can`t get my palm to cennect with my computer because of the security on my linksys. when I go to security they ask me to select none, WEP or WPA-PSK , my security connection has a 10 alphanumeric code and they are asking me for 4 or 5 digits? What can I do
    Problem Solver:
  • 14 Answers
Hi. try this.
have the tx search for you network using the wifi button at the bottom of the screen.
select/highlight your network and click edit. note do not connect to it yet
click configure.
on the security, pull down the arrow and pick WEP (or WPA according to what your router has.) note that since you mentioned the 10 digit alphanumeric code i assume it is WEP
on the key type click on 40 bit hex
i usually leave the four keys unchecked. (unless you have 4 keys)
insert your alphanumeric key that you use to protect your network into the dotted line.
click yes to connect. enjoy.
if your pda has connected and you still cannot get your internet, please read below.
PS. some internet servers may require a new user to input a name and password as a safeguard. this is familiar when you try to log into a public wifi hotspot with your laptop and the web browser always redirects you to an agreement page.
if this is so, what i do is to run my internet browser. let it load the first page then i accept the agreement and i am in.
hope this works for you. please feel free to email me with any more questions.
Posted on Nov 10, 2007
Can only connect 2 computers
Yes, the Linksys Wireless-G WRT54G Router will used to connect the computer wirelessly by using the security keys.
You will have different combinations of encryption or security keys.
Jan 22, 2011 | Linksys Wireless-G WRT54G Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for or you modem cause if you do you'll need to change the ip address on the linksys router...
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
I'm having a problem setting up my linksys wireless router. My computer sees the connection but will not connect to it? I've tried the repair option and tried to add a network with out any luck.
As i remember Linksys goes with Straight Through Ethernet cable. Always, good thing is to connect your computer to Wireless Router using LAN port. Set DHCP (Automatic) connection for your computer. After receiving ip from router you can setup your Wireless Router using GUI, and setup your Wireless Network, SSID/Security. From adapter to adapter there can be some misc problem with WEP/WPA/WPA2 and so on, so it maybe your issue, or OS blocking connection to Wireless Networks without security.
Apr 18, 2010 | Linksys Wireless-G Broadband Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
Unable to use Wireless Security Option when using multiple PCs
Just try to enable your security in WEP mode instead of WPA mode and then try to connect,it should connect as WPA encryption is not supported by windows ME.
Jun 05, 2009 | Linksys WRT160N Wireless Router
Cannot get a second computer on my secure wireless network
Have you set the properties on the second computer to match the security expected by the router? Since one computer works I would compare the settings for the network connection and set the second computer to the same.
Mar 15, 2009 | Linksys Wireless-G WRT54GS Router...
Changing router settings from 802.11G to mixed w/802.11B
Switching the wireless mode is easy, and, if you choose "mixed," the other computers in your home can continue to use the G mode unaffected. How you adjust the mode depends on the brand of router. Since Linksys is the most common, here is how it works on a Linksys router:
1) Open your web browser (IE, Mozilla, etc.)
2) Type the web address (default for Linksys routers).
3) You should be asked for a username and password. The default for Linksys is username "admin" and password "admin" OR username "admin" and password [blank].
4) You should then see the Linksys setup screen. The tabs across the top include Setup, Wireless, Security, etc. Click on Wireless.
5) Pull down the menu next to "Wireless Network Mode" (which shold be set to "G -Only" and choose "Mixed." Then click "Save Settings."
This should allow your B-capacle Palm to use the network without a password while still allowing your encryption-capable computers to use the G mode.
I hope this helps - please let me know if I can be of any further assistance.
Dec 14, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Palm tx
Does your linsys router have MAC filtering turned on in the WI FI settings?
Apr 06, 2008 | Palm TX Handheld
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Palm TX Handheld Logo
107 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
