Question about Zenith B32A24Z 32" TV
Need capacitor specs
Sure could use the capacitance of cx3210 and cx3211
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Please check scmematicas given in web as shown& find the value http://www.eserviceinfo.com/downloadsm/20265/_SAR%202953%20BT.html
Posted on Oct 01, 2007
SOURCE:
What size of stating capacitor would be used for a 2.2 kw motor i phase
the capacitor is critical to the motor it is connected to.
there is no straight forward regular relationship between capacitance and the size in kw
ref --www.electricneutron.com
the required capacitor will be listed on the motor specs plate that has all the details for the motor
Jan 09, 2017 | Air Tools & Compressors
Where can i buy an icar ecofill WB 40500 serial no is 99-26AS ?
I was unable to locate this capacitor by its number - no hits on the web. However, if the original capacitor has the specs on it ;voltage and capacitance, you will be able to find a replacement going by the specs. For instance, if the capacitor is rated at 300 volts/ 12 mfd, you can do a search for " motor capacitor 300 v/12 mfd.." these numbers are just for example. You need to look at the one in your power washer for its specs.
I replaced the capacitor on my power washer with one I located on the web that had the same specs as the original, and was pretty inexpensive. The capacitance does not have to be exact. If the original spec is 15 mfd, and you find that is 14 or 16 mfd that will work fine. Also the voltage rating can be higher than the original.
Jun 07, 2014 | Garden
On a Sears Craftsman 20 gal air compressor model # 921.166430 I need the start up capacitor. Where can I get one?
Capacitors are generic components. They are not made for a specific compressor, like a mechanical part. You need the voltage rating and the capacitance. The capacitance will be a number like 5uF or 10uF (uF = microfarads). Then you can go to an electronic supplier that handles small orders, like Digikey, and get a replacement. I have seen them on Amazon as well. I got mine on ebay. Just make sure it will meet or exceed the AC voltage rating. Some capacitors are made to only handle DC, like electrolytic capacitors. They have a + & - marking. These will explode if you try to use them. On the replacement, you can exceed the voltage rating, but the capacitance needs to match pretty closely since it is tuned to the motor's starter winding to create the correct phase shift to start. If the phase shift is off too much, you won't have enough torque to start up.
Oct 13, 2013 | Air Tools & Compressors
Motor doesn't start
You will need a meter that reads capacitance or microferads.
the capacitor will have it's rating and range printed on the side.
For instance, if you have a 35 microferad capacitor, and it has a + or - 10% range, the capacitance reading would need to be between 31.5 and 38.5.
If the capacitor is leaking or swollen, then it is obviosly bad.
Make sure you disconnect the power first, then discharge the capacitor, (using a screw driver touch both terminals together.) and remove the wires from the terminals before testing with the meter or you will get false readings.
Oct 04, 2009 | Kitchen Appliances - Others
Need to know the value for Capacitor CX3211 on the edge of the board. The CX3212 next to it reads HR R 561K 2KV and I wonder if they are the same. THe CX3211 burned and the TV died. I am layed off and...
The value of CX3211 is 1000pF 10% 2000V, ceramic disc.
You can also download the service manual from this website. Make sure to download all the 7 files.
Good Luck.
Jul 26, 2009 | Zenith B27A11Z 27" TV
Lost components vakues
Download the parts list from this link. You should find the parts listed.
Jul 25, 2009 | Zenith B27A11Z 27" TV
Need to replace capacitor on dvd player
Hi, you should use a capacitor with same capacitance of 1000uF, but you don't have to stick to the original voltage spec. 1000uF 10V means it can withstand 10V load. 1000uF 50V means it can hold 50V for the same capacitance. Today I fixed my friend's and for that I used 1000uF 35V from RadioShack. It perfectly works - and it's better. But you shouldn't use 1000uF 5V - by now you already know that :)
May 03, 2009 | Philips DVP642 DVD Player
UNIT IS DEAD.
believe are the two caps., beside the large H.V. transformer? Just replace the two capacitors and should be fine, I have this problem before. Now as far as open neutral there maybe other damage to the set.
Nov 22, 2007 | Zenith Z27A11G 27" TV
UNIT IS DEAD.
Reverse Phase Can do that on Ac expecially when the Cable is Connected,Replace both Caps and Ck the MOV also the full wave Bridge 4 Diodes and Fuse should restore Full Operation Good luck ttech
Jul 24, 2007 | Zenith B32A24Z 32" TV
Zenith B32A24Z 32" TV Logo
101 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
