Question about Dell 1700n Laser Printer
Dell 1700n paper jam
I had a nasty paperjam that came out piece by piece. It seemed cleared so I tried printing again. No luck. It says it's jammed but I can't find evidence of it. The page pulls in fine and starts to go through the printer and even through the "heater" where the toner is melted and then the "jam" light comes on. I open the back of the printer and the page is just sitting there unstuck, unwrinkled. It's like it just won't go up to come out of the printer. If it fed about another inch I could pull it out of the top. I don't understand it.
  • dellgeek Oct 01, 2007
    That's the most obvious thing and I've done that. People that can find this site should know to do that.
  • Anonymous Mar 18, 2014
    The printer is making a new clicking noise now and i cannot print at all. The noise is coming from the left hand side. Has been working fine up until i pulled the toner out and put it back in again.
  • 132 Answers
Most larger printers like yours have an optical sensor that needs to have the paper pass by in order for it to send the "sent" signal. If the paper doesn't trigger that you get the paper jam error. look at this page it will tell you what and where to check for your problem. It has photos and videos. I hope this helps some.
Posted on Oct 01, 2007
This occured on a company Dell 1700n. I couldn't work out what it was at first because the paper was not jammed and the rollers appeared to be fine. I removed the printer tray, pulled on the feeder mechanism (it's hinged with a spring and lowers into the tray to press against the paper) in a downwards motion and there was initial resistance followed by freer movement (and a slight click). After replacing the tray and powering on again it appears to work.
Presumably that feeding arm mechanism gets stuck sometimes. Some WD40 on the joint would probably also help as a maintainence procedure.
Posted on Oct 19, 2007
  • Dell Master
  • 2,022 Answers
First you reomve your toner and see is ther any paper inside if you are able to open the back cover just open it and try to remove the paper from drum assembly. bye
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Every page i try to print is says i have a paperjam clear the jam and press enter so i clear the jam and press enter nad it prints and then says exactley the same with every page i try to print and there...
First, lift the top of the printer up past the sensor. This usually resets it or try turning it off, waiting a minute or two and then turning it back on. If this doesn't clear it and it the paper doesn't move through the printer straight, there is a small torn bit of paper somewhere that must be removed. Good Luck!
Hair, ready to go, ready to wear!
Sep 21, 2010 | HP OfficeJet 6110 All-In-One InkJet...
When I print, the paper gets jammed at the same place. I have cleaned the rollers, but it still gets jammed.
You can try using the next heavier weight of paper, or the next lighter weight. Not uncommon for laser printers to start jamming when humidity changes.
Jun 13, 2010 | Dell 1700n Laser Printer
Error message on Lexmark x5470
hi there: we have the same printer and we had the same paper jam problem to correct: this we opened it up as normal and than got a flashlight and looked real closley at it and there was a verry small piece of paper in the side of it folded and caught in it we took a pair of tweezers and removed it and the paperjam was cleared try that ok the smallest piece will give you this error and wont continue untill it is cleared
best of luck mike
Feb 09, 2009 | Lexmark X2500 All-In-One Printer
Printer jam on Dell 1700n
the sensor is on the back of the fuser, it's the small black plastic piece that the paper hits as it passes through. (or is supposed to) online suppliers have this part for under $40 us. it's an exit sensor.
Nov 07, 2008 | Dell 1700n Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Jam trouble
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Feb 25, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
1,014 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
