Question about RCA F36650 36" TV
Unsticking top control buttons/relacement part for top control
Having same problem fredmertz had and channels just changing when any button onthe remote is pushed. Also when a button is pushed menu items appears and no way to control them. I think its the buttons up top but need to find out how to unstick them and exact part number for control to get a replacement. Partstore.com was not specific on the part needed.
    Genius:
  • 1,694 Answers
Replace buttons w/RCA part #249693. If tactil switches are bad==part #245531. replace all six, if needed.
Posted on Oct 01, 2007
SOURCE:
Control panel buttons
spray with wd 40..
Dec 08, 2013 | 1997 Acura RL
We dont have a manual and we dont know how to change the channel or set the time
To set the clock on the unit, have the TV connected to power but not on. Then press and hold Mem/Clck Adj on the TV (it's the third button from the right in the top row of controls). Use the adjacent Tune/Clk (up/down arrows) to set the clock for 12 or 24 hour time. Then press Mem/Clk Adj again to adjust the hour with the up/down arrows. Press Mem/Clk Adj again and set the minutes. Press Mem/Clk Adj to save the time. The original remote also has these buttons. Mem/Clk Adj is also labeled Set and is the furthest right button on the second to bottom row of the remote. The Tune/Clk buttons are the DN and UP buttons on the left of this row.
Use the Tune/Clk arrows to change the radio channels after pressing the radio button (second from the right on the bottom row). When you press the TV button (first on the right of the bottom row) to watch TV, then you need to use the Channel up/down arrows at the top and bottom of the ring control on the far right of the TV or the Channel + and Channel - buttons on the remote. On the remote, the Channel + button is below the timer button which is below 9 in the keypad section. Enter is below the Channel + button and Channel - is below Enter. Make sure that the TV is in the correct mode for your signal (ATSC for OTA and NTSC for analog cable) by pressing the TV mode button. If you are using a set top box, you will need to change the channels at the box.
Press the TV Menu button and then go down the list to Time to set the time zone for the TV. Press Enter to save the setting. Use the TV Scan button to get a list of available channels before trying to change channels.
The manual for the GPX KL868S is available from GPX at the product page: http://www.gpx.com/store/p/287-KL858S.aspx . The direct link to the English version of the manual is: http://www.gpx.com/owners_manuals/KL858S-IB.pdf .
I hope this helps.
Aug 22, 2011 | GPX KL858S 8.1 in. Under Cabinet TV
My remote control will not work. I changed the batteries; still won't work. I don't know the reason but when Comcast Cable they brought a Comcast remote which controls only changing the channel's. The...
could be a stuck button press all the buttons on the tv a few times so see if it will unstick or take the remote and a camera phone point the remote at the phone camera and press buttons if you see a flash then the remote is working. if no flash then the remote is defective. if all the buttons on the tv work correctly then it may be a IR sensor problem or mainboard communication problem.
Dec 23, 2010 | Televison & Video
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 16, 2010 | Haier HTF20 20" TV
Can't change the channels
Whenever a remote is not working to change channels thefirst thing to check is the batteries. Even if some buttons on the remote areworking, it is possible that low batteries are the cause of not being able tochange the channel. Once the remote has fresh batteries, you'll want to makesure that the remote is in the correct mode. This can be done simply bypressing the 'SAT' button and it should light up. The next thing to do isre-address the remote to the receiver. First, press the 'system info' button onthe receiver (or access system info through the menu). Once the system infoscreen is showing on the TV press the 'SAT' button once and release then pressthe record button. The remote should then be working with the receiver.
Kaia S
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Oven showing f7 on lower oven
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning . F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control. you can get the required parts at www.repairclinic.com thanks.
Jul 11, 2009 | GE Profile JB968 Electric Kitchen Range
TV won't stop changing channels
Main board needs replaced !
Jul 03, 2009 | Televison & Video
Double GE wall oven - F7 code
from repairclinic.com:
Apr 27, 2009 | GE Ovens
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
RCA F36650 36" TV Logo
100 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
