Question about Toshiba TP50F60/61 TV
Tv needs fixing, advice appreciated
Got this tv for free from my grandma. after the move it worked great for 2 days. then it would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. this morning i turned it on with a black screen. It has audio but no video. after several minutes allowing it to warm up it clicked off and went to a blinking red light. i will replace convergence ic's and resoldering leads is there anything else i should be looking/testing for?
  • jabba1 Oct 01, 2007
    it had convergence problem before it was moved as well if that helps
  • pgannon007 Dec 07, 2008
    The screen goes blank....it comes back but happening with more frequency....audio has no issue, just videe screen getting bowed, not 100% picture and going black.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. it was nothing but due to change of place due to decaussing ckt to take care of magnetic effect of earth. this morning i turned it on with a black screen. It has audio but no video. your problem it sounds me that it is due to loose contact or loose connector or due to video ckt. as you said that sudio is ok. if you are not tech person call skilled tech to fix it .it is not a major problem. hope this will help you please let me know what happened.
Posted on Sep 30, 2007
How to fix the back-light on Phillips TV (40PFL4706/F7).
we had one doing this and took it apart. found one of the backlight diode lights blown, you could see it was burnt. ours had strips with led's on it. we found a number on strip, went to amazon and ordered one. it fixed it... so far
Jan 16, 2018 | Televison & Video
Tip
Great advice. I was able to replace my dog ears today with your help. Mine was a...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature. For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Aug 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Why is hvac air coming from all three locations (vent/floor/defrost) regardless of switch setting?
Check air box if it won't change air flow some thing is wrong there inside the car
Jul 14, 2014 | 2000 Buick Regal LS
Fix high voltage shutdown
be looking at the system fuses..or power relays..
Jan 08, 2014 | Sony BRAVIA Televison & Video
I have a Samsung HP-S4273 Plasma TV. It was purchased in the USA, so runs on 110-120 V 60Hz. I am moving to Australia next year where the supply is 240V 50Hz and also a different TV format (PAL/SECAM vs...
Sell it as a second hand tv,get,what $ u get.Sorry,if ur tv is not a Region Free tv Systems.It,will run only on NTSC signal frequencies,will not run on PAL signal frequencies.Ausi as u know,run on PAL and 240V 50Hz.Will work with a step-up tranformer,but if only,if ur tv is a Region free tv Systems.
Nov 02, 2010 | Samsung HP-S4273 42 in. Plasma HDTV
Dryer won't stay on
http://136.166.4.200/contents/Laundry/DLE8377/DLE8377_Service_Manual.pdf
Hi, above is a service manual, download, this has all troubleshooting and repair advice. Follow the troubleshooting procedure and you will soon isolate your problem, and hopefully fix.
May 12, 2010 | Whirlpool ET8CHEXSQ Dryer
40 in Panasonic Vierja turns on and off intermitently
I got hold of someone who really wanted to give advice that I could use and decided NOT to ask someone who felt they had to charge for "giving advice."
Apr 12, 2009 | Panasonic Televison & Video
Black vertical line
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Dec 30, 2007 | Televison & Video
TV just shut off one day...
This sounds like a PSU fault. Since ther is no way to determine your expertise then the best solution is to call an engineer.
Oct 06, 2007 | RCA F32632SB 32" TV
Televison & Video Logo
114 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
