Question about Zanussi TC180W Electric Portable Dryer
Kenmore dryer isn't working
I was given a Kenmore electric dryer (no book or anything with it). It does not get hot and now it won't shut of. I can run it and a normal large load will be dry in about 2 1/2 cycles. Yesterday it stopped shuting off. I had no idea until I discovered that it had run all night. I checked the vent/hose and it is clear all the way out of the house. I was thinking element but then wasn't sure when it started to stay on. The timer gets right to the end, just stays there and keeps running. Help! This was to replace a broken one!
  • mckain Oct 01, 2007
    Okay I tried that and the air coming out of the dryer was stronger than what comes out of the vent hose but still no heat or shutting off. When we put it in the outlet had to be changed, a friend had one that worked with the plug. Could the fact that it was an older outlet have any effect on this? Or am I looking at a new element and something timer wise as well?
  • 447 Answers
Was the previos dryer taking a long time to dry??? Make sure a high velocity of air comes from the dryer with the vent unhooked there may be a internal restriction causing the long drying times, if there is no restriction then it is in the home vent line. To verify that it is a vent issue unhook the vent and do a load of clothes if it drys in 40-60min it is the vent.
Posted on Sep 29, 2007
SOURCE:
Kenmore gas dryer won't get hot
gas--- glo bar that lights the gas is bad or the vent to the outside is clogged electric-----wire may be burnt off the heating element or element has to be replaced
Jan 14, 2013 | Dryers
Kenmore gas dryoer model #11073912100 not getting hot, all vents cleaned out, still won't work. could it be pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 11, 2011 | Kenmore 74112 Gas Dryer
The heating is not working properly, not hot enough. I tried 3 hours, but the clothes still not dry. It is a 120V Kenmore dryer.
IF THIS IS AN ELECTRIC DRYER 110 VOLTS ISN;T RIGHT 208 VOLTS SHOULD BE MORE LIKE THE ANSWER. IT TAKES 208 VOLTS TO RUN THE HEATING ELEMENT AND 120 VOLTS FOR THE MOTOR
SOMETHING DOSN'T SOUND RIGHT THERE
Feb 06, 2011 | Kenmore Dryers
My dryer isn`t get hot. What should i do? kenmore-400. I live in Pembroke Pines. Florida
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | Kenmore 400 6943 Dryer
Kenmore Dryer Model 417.92142101 does not heat up. It looks like the element is getting hot but the gas does not light
Hi, Hey, that thing can get red hot and still not be working right... If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 20, 2010 | Kenmore Dryers
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
May 26, 2009 | Kenmore Dryers
Zanussi TC180W Electric Portable Dryer Logo
108 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
