Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune fronmt load washer Model MAH5500B
My washing machine fills up then all of the lights start flashing and a LR appears. Have tried unplugging, restarting, etc. but nothing works. Any suggestions? Thanks!
  • sunnyday Oct 02, 2007
    Called Maytag and they are sending out a tech. Thanks for your help.
  • 447 Answers
Lr means locked rotor basically you have serious problems i would call a service tech for this.
Posted on Sep 29, 2007
  • joey  shearer
    joey shearer Oct 02, 2007
    Yes unfortunately that means the computer has tryed multiple times to engage the motor and it pulls high amperage and no rpm is detected. Hope it under warranty. See ya
SOURCE:
Neptune error code LR, means what?
Maytag & whirlpool was recall Maytag Neptune MAH5500B.
Oct 16, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag model MAH5500B that starts to fill , stops and LR appears in indicator lights. Any suggestions?
remove the belt from the motor pulley and make sure motor spins freely,check the 3 windings with an ohmmeter for appx 8-11 ohms each,then check all connections everywhere by removing and reinserting them,then try to run the diagnostics from the tech sheet inside the washer,if all this fails then replace the M.C.U. motor control unit
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washer will not complete the wash cycle. Lr
http://www.servicematters.com/maytag_library/docs/TDL-0044B-B.pdf
If all else fails, replace motor control board, and/or motor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code Lr
locked rotor you need a new motor control
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer mah5500b
Replace the door Wax motor & main Control Board.
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
342 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
