Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell ProHeat Carpet Steam Cleaner stopped spraying.
My Bissell ProHeat Carpet Steam Cleaner (Model 7920) worked great for 6 months. After that, it would occasionally not spray solution/water when I pressed the trigger for spray when cleaning. I would take the water canister out, check the bladder & gasket & connections where the container met up with the base of the machine to make sure there was a connection. Then, it would spray again for a while. Now, I cannot get it to spray at all. The vacuum/suction function works, just not the trigger/spray.
  • 3 more comments
  • ohshirley Nov 15, 2007
    I cannot get mineto spray,,,,,,,,,,It will suck up the watr, but will not spray,help....................................... shirley
  • Anonymous Nov 18, 2007
    Same here..The gasket fell off. I fixed the gasket. The water tank cap leaked real bad. I had to order one. I never got to use it again. I used it only two times since I purchased it last spring. Now it will not spray solution. the hose attachment does. What can I do?
  • Anonymous Mar 25, 2008
    yes ido please help
  • ez58790 Jan 28, 2009
    my bissel puts out the soap solution but not the water,
  • egreene17 Apr 09, 2009
    I am having the same problem, but my Bissell does not spray water at all. We took it apart and troubleshot it, but nothing worked. Has anyone found a trick to fix this problem?
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Posted on Sep 19, 2009
  • jjbarragan Feb 19, 2011
    Thank you so much. Mine would not spray and I followed your directions and it WORKS!
  • 48 Answers
The inlet or outlet of the heater could be blocked with lime scale if its an older model.
are the spray tips clogged, turn the machine over, these are uder the brush ,
the filter could be block under the flow indicator,
take of the clear cap wich the spinner is located in there is a white filter under this ,see if its clean.
Posted on Nov 22, 2007
  • 1952 Nov 22, 2007
    make sure when the trigger is pressed the plunger is reaching the valve
Mine would not spray at all after one use...took it in to repair shop and was told to always run clean water through machine after shampooing because the soap thickens and clogs, in my case, the heater.
Posted on Sep 08, 2009
Check out Chocolate69, solution#3. It is right on the money, and very easy to do. It seems most, if not all spraying problems relate to the heating unit getting clogged. When you open yours up to clean it you'll see what I mean. And once again, it's an easy job. I didn't feel it necessary to disconnect any electrical just the two water hoses for cleaning. Good Luck To All!
Posted on Oct 04, 2009
Problem could be a stopped up heater unit which is located in the handle. The two clear hoses going up the inside of the left wheel go to the heater. There is also an in-line water switch located directly above the heater. The trigger for water release is in the top part of the handle. back to the heater... mine was corroded inside. Removed 5 screws holding heater cover. clean water trough and reassemble. If you need new washers go to Ace hardware. The smallest size metric rubber washers seem to work fine. take old rubber washers(red?) with you for comparison.
Posted on Mar 03, 2008
SOURCE:
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
WON,T SPRAY CLEANER/WATER CARPET IS DRY.THE TOOL ATTACHMENT WORKS OKAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 08, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Plus carpet cleaner does not **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
dghdgh
Jan 04, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
No water or solution spraying
Used an air compressor to clean out the clogged tubes
Jul 18, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
4,582 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
