Dryers
Problem for Dryers
Generic problem for all Dryers
Tumble dryer
By drinkben on Sep 29, 2007
how to change belt tl14p
Same Problem
Jun 08, 2008
-   Got the belt around the tub but can't figure out where the tension the thing that has a little wheel -   loretta30
Dec 29, 2007
-   Don't know if it's the same problem, but ours is making a thumping sound during each revolution of the drum. Looking for a starting point.-   Guest
Best Solution
posted on Sep 30, 2007
Helpful)
Cerfer39
Rank: Guru
Rating: 87%, 1154 votes
Hi Drinkben,
Pull the dryer out and disconnect the power. Pop the top up and raise it like the hood of a automobile. The Front that the door is hing from will either pop off or you may have to remove screws to get the front to come loose. Once the top and front are dsilocated, you can clear the old belt.
Put the new belt over the drum and raise the drum a bit to allow the belt to go undeneath. Thread the belt so that it araps the tensioner and around the motor pully. Roll the drum by hand to besure the belt tensions properly. Then reassemble the dryer. Plug n the power cord, and slide it into place. This is an Easy job to do and with your Ingenuity , I am sure this will help you complete the task.
Was this helpful?
Yes
No
8 people thought this was helpful
Popular Solutions for Dryers
Questions and Unsolved Problems for Dryers
Answer
dryer will not heat and heating element is good.
Answer
how about a 100% dryer and tell me about the advs and disadvs
Answer
Dryer works perfectly...but has no heat. All filters clean. Heating element, or thermostat?
Answer
how do you set the time/temp on a indesit dryer SG510K
Answer
i have a zanussi tc7102w condenser drier ,drum not turning , removed lid found large belt broken,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dryers:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
