Question about Philips 32PT9100D 32" TV
TV cuts out randomally
I have a Philips TV that works fine when you start it up, howevery anywhere from 10 min to three hours it shuts itself off. The light blinks red, the only way to get it working again is to unplug it and plug it back in.
  • teschwan Aug 26, 2008
    t.v. shuts off after it has been on for 1/2 hr to an hour. is this a problem to be fixed by a professional?
    Genius:
  • 1,694 Answers
Look for over-heated area on PCB==solder bad connects & replace 47m/25v cap in horiz drive circuit.Replace damaged xistors in same area.
Posted on Sep 29, 2007
1986 Lincoln Town car 5.0 intermittent stalling problem, usually while driving. fuel pump?..please advise! Thx!
It appears you may have a bad ignition coil that cuts out after it gets hot. Not uncommon.
Aug 16, 2017 | Lincoln Cars & Trucks
Magnavox 46" LCD TV shuts itself off after a random amount of time.
Is there a person in your environs who is mischievous or prone to malfeasance? Someone may be using a TV-B-Gone on you. Check this out:
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
Apr 14, 2014 | Magnavox 46mf401b/f7 46 Hdtv, Lcd 1080p...
Lcd tv shuts off by itself and then turns on by itself
philips tv turns itself off and on agianevery 10 mins roughly with a gap of a few mins before coming back on. only had a few months
Dec 27, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
Dryer will turn on sometimes, but will cut off randomly!
Check your vent pipe(s) and the lint screen areas .. it sounds like you have blockages and that causes it to shut down .. Check completely from the back of the dryer all the way to the outside vent ..
Mar 23, 2009 | Whirlpool Dryers
Zenith dlp projection t.v. model#z52sz80 t.v. turns off randomly
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Feb 16, 2009 | Zenith Z52SZ80 TV
Philips 42PF9630A
Go to philips website and download the latest firmware and install via usb. The fw corrects random power on and offs. If that doesnt fix your problem, the tv is going into error protection mode do to a voltage problem detected by the power supply.
That will be hard to diagnose as everything will test ok as it works before shutting off. The best way is to run the set and use a temp gun to find out whats overheating and go from there.
Aug 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Philips 32PT9100D 32" TV Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
