Question about RCA F32450 32" TV
High Pitched wine when turning on
I have opened the back (carefully, know the dangers) and listened to pin point the wining sound. It is coming from the circuit board on a part with the following numbers: PN 1536335A D1 15363340 RXETCE02215 This part has a crack in it through the top black section. Overheated? The TV will not turn on with remote nor with the button on top. Just wines.... Is this worth fixing?
  • 4 more comments
  • Anonymous Dec 04, 2007
    I have the same problem and i did the same thing.
    I have the same numbers except for the 3rd line of numbers/letters
    mine is EXETCED2256
    I would like to know what that part is called, where i can get it, and how to take it off.
  • buzn8r Nov 06, 2008
    I have the same problem. At first I thought it was the Flyback transformer, but more careful listening revealed that it was this other transformer. I cannot find it anywhere. Where can I buy this part?
  • Anonymous Dec 03, 2008
    I have the same issue TV just stopped operating, I can not turn on or have any audio, the high pitched sound remains unless you un-plug the unit. I purchased the set on Jan. 03' and have had no issues up to this point. Did anyone find the part? Price? Thanks
  • Anonymous Dec 19, 2008
    I have the exact same problem. How do I fix this? What will I need to buy?
  • Anonymous Jan 21, 2009
    sounds the same to me, but is there anyway to fix it myself? A skilled technician would cost more than the tv!!
  • bajancodgie Feb 11, 2009
    I am a technician and i have the same prob with tv. the horizontal output is shorted but it seems as though the flyback is faulty also but not sure. thanks for any info given.
    New Friend:
  • 9 Answers
I found the part (transfoemer) on Ebay for $15.00 + $7 for shipping. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160449088402&ssPageName=STRK:MEWNX:IT
Posted on Jul 12, 2010
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Yes it is worth fixing & not that serious. but please call skilled tech to fix it as high voltade is inside even it is off.if you are not a tech person.
Posted on Sep 30, 2007
6ya staff
SOURCE:
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Do all California wines contain arsenic?
Yes, all California wines have some arsenic in them, but so do most plant based foods. Arsenic occurs naturally and is only dangerous in high amounts. I've linked an article from NPR that might help.
Arsenic In California Wines Should Drinkers Be Concerned
Apr 26, 2016 | Furniture
Soda cooler is making high pitched noise, like running a finger around a wine glass
Sounds like your condenser motor is ready to give up. Time to replace it let me know and I can supply you with the new motor.
Apr 18, 2013 | True Refrigerators
1999 olds alero, high pitch wining coming from component end of engine
The only thing that would cause this is a faulty power steering pump. Any shop can listen and confirm this.
Nov 06, 2012 | Cars & Trucks
The temperature in my wine rack went under 12 Celsius does it means that my wine is ruined?
When it comes to cooler degrees the only thing you should be worried about is the time that will take your bottles to age. When the temperature is below 10 Celsius the aging process stops but there is no danger to your wine at all.
Aug 13, 2012 | Furniture
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
97 f-150 high pitched wine from radio, buzzing behind instruments
If the whine changes pitch with engine RPM it could be a serious problem with the alternator. Possibly the voltage regulator, or a shorted diode in the alternator causing high frequency AC to be fed into the harness.
Oct 09, 2009 | 1997 Ford F150 Regular Cab
RCA F32450 32" TV Logo
394 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
