FixYa.com
Tags:
BenQ PE8700 Multimedia Projector
BenQ 8700
posted by steelerfan on Sep 29, 2007
I recently moved and had my projector installed and now I can't get the aspect ratio off the lower left corner of my screen.
Any ideas on how to remove this from the display?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 04, 2007
Not Rated (0)
Jazzdoc
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had a similar problem with my Benq 8700+. The aspect ratio would show in the R low corner on changinbg resolutions, and would close down to a single line ("anamorphic" for example) which would remain on the screen. I checked the manual (useless) and went through all the set up screens (again useless). In despiration, I decided to try to unplug the projector and did so for 30 seconds to allow the charge to drain from the circuits powering the chips in the 8700+. Upon returning power and restarting, the screen resolution appears/disappears properly once again. Give thjis a try.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
Please tell me how to reset...
Please tell me how to reset... Answer This...
RCA to DVR
How can you connect a RCA... Answer This...
Maintenance Nec vt480
I need maintenance for my NEC... Answer This...
Preylahong NEC MT830+need help...
Hello, Marrie if you can help... Answer This...
update BenQ PE8700
Hope this is not getting too... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
