Question about Motorola Mobility HS850 Consumer Headset
Motorola HS850 I can't get the blue light to come on. I put it on the charger because it wouldn't work. The blue light never came on; I left it there for a couple of hours hoping it was something minor and would eventually start working. Well to my surprise it?s not working. I have tried everything in the user?s guide twice and it still not working. I pressed and held the multifunction button E and still no activity. Do anyone have any suggestions?
  • 5 more comments
  • Anonymous Nov 08, 2007
    I also have the HS850 Bliuetooth . It has been sometime since I have used it. The problem is it will not turn on it seems. The blue LED won't flash. It seems like it's not even charging. I think it's possible that I need a new battery or a new charger. If anyone can help I would appreciate sooo much. THX...
  • Anonymous Nov 09, 2007
    tHE BLUTOOTH WILL NOT CONNECT AND THE LIGHT WILL NOT COME ON AT ALL.
  • Centac02 Dec 12, 2007
    HS850 will not power up. Charging with ac or dc will not charge unit. No light.
  • Anonymous Aug 08, 2008
    Same issue. I found out by jiggeling the cable around, the light would come on but only for a second. It seems to be a problem with charger or the input of the HS850. I have to send it back and see if a replacement works.
  • Anonymous Jan 07, 2009
    The light comes on when charging, but when I unfold the boom, the light does not blink or even show up
  • Anonymous Feb 05, 2009
    I had the same problem, but after reading here I started jiggling the connector and the blue light comes on. However, it will turn off now and again so I have to go wiggle the connector again and the blue light comes back on. It's a pain the a__ but I was able to get a full charge from this process.
  • Anonymous Feb 24, 2009
    Battery does not take charge. I want to replace it.
  • 3 Answers
Close the boom and hold multifunction button E when the blue light lights up open boom.
Posted on Oct 08, 2007
The pairing light on my HS850 soes not come on?
You have to start with the boom closed and press the large button with the phone symbol until the blue light comes on, then open the boom before the light goes out and you should be able to pair it with your phone.
Feb 26, 2010 | Motorola Mobility HS850 Consumer Headset
I cannot get my phone to locate my motorola hs850 what do i need to do?
close the boom mic , press the button and hold until blue light is solid and with your spare hand flip the boom mic back open and the light should remain on. "0000" is the default passkey
Jul 05, 2009 | Motorola Mobility HS850 Consumer Headset
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 17, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Having problems pairing
Apr 12, 2009 | Motorola Mobility Universal Wireless...
My hs850
Press and hold your power button for about 10 seconds, unitl the blue light starts flashing. Most people just push the button and think it will turn on, but you must hold it for a while and it will turn on.
Aug 15, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Nextel I870 phone and my HS850 blutooth
hold down hook button until blue indicator goes solid blue
(mic FOLDED IN) flip out mic quickly and go to settins on phone and select bluetooth or connections and select find/add bluetooth device and select bond or pair enter passcode 0000.
select done and blue light should now be blinking indicating it was connected
Jan 09, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
221 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
