Question about Toshiba Satellite M45-S331 Notebook
DVD RAM drive not recognized
I have a DVD RAM drive and recently it had not been recognized by the computer. It is like the computer doesnt realize the drive exists. When I go to "My computer", the drive doesnt even show up. I uninstalled and re-installed the driver and it was working for a time, but now the same problem is back. When I tried to the same thing again, a msg pops up saying that I already have a functioning driver. What should I do?
  • Anonymous May 21, 2008
    I did both your ideas, so not sure which one fixed the problem. Toshiba also just put a new DVD driver on their website so I DLed and did what you said and its working now - yay!! Thanks to both of u!
    Novelist:
  • 94 Answers
Another thing to try: Sometimes the cd/dvd drive gets partially unseated where it plugs into the motherboard (kind of like when Nintendo cartridges didn't work correctly when they weren't in "just right"). This can happen just from regular use over time and from resting the laptop on uneven surfaces (like your lap). This can cause your laptop to a) not recognize that the drive is physically still there, and/or b) prevent your laptop from booting up correctly (or at all) if your computer freezes before or during the boot process.
The fix is as follows:
(Warning-only do this if you either a) know what you're doing, b) check your manual to identify the correct things to touch, c) all of the above.)
Power off the computer. Remove the cd/dvd drive retaining screw, removed the drive. Reinsert the drive, and reboot.
If this is the problem, this fix should take care of it. It happens more often to laptops than people realize.
Good luck, and let me know how you make out.
Posted on Jan 04, 2008
    Sergeant:
  • 457 Answers
Update the bios that is the first one that recognises your drives update that thn have a look. Or check your Bios setup it may not be configured to load the CDROM Drive.
Posted on Sep 29, 2007
SOURCE:
My laptop doesnt have the cd drive. It doesnt read my cd or dvd..
If you have more than one computer and other computer has dvd drive or cd drive you may use it by networking this computer to that one! You may also by external cd/dvd drive for your computer as well which may be easier!
Sep 14, 2011 | Computers & Internet
I HAVE PROBLEMS WITH MY ACER ASPIRE M1100 COMPUTER,WHICH I PURCHASED IN 2008. SPECIFICALLY, THE DVD RAM IS NOT FUNCTIONAL AT ALL. THE CD RAM HOWEVER, IS WORKING JUST FINE. PLEASE, HELP ME FIX THIS...
You better check the DVD if this is recognized by going to My computer > Device manager > DVD/CD-ROM drive and see if mark as ( ? ) question mark. also check the IDE slot as well as cable if its properly attach or insert,try to change IDE cable at least. Check the power supply socket all going thru your DVD, might no supply or power entering the drive that's why it's not recognized.
Good luck.
Jun 27, 2011 | Computers & Internet
Hi,not a computer type dude.Bought HP GSA-T20L for my Toshiba Portege M100. Doesnt recognize/acknowledge drive when computer is turned on with drive installed but if is plugged in once awake will work. ...
usually if the drive and pc has same type for example SATA drive to sata pc its must copatible, was you check that slot?/other suggestion is was your drive driver installed properly??may you use win 7 64bit and your driver is for win7 32bit, if like that reinstall your drive driver that compatible with win7 64 bit
Jan 23, 2011 | HP Hewlett Packard HP Pavilion DV2000...
My computer doesn't register the ne.ASUS DRW 24B1ST - Disk drive - DVD±RW (±R DL) / DVD-RAM - 24x24x12x - Serial ATA - internal - 5.25" - black I had a ATA before and have now got a sata. The...
goto device manager,,...Open the "Run" dialog box by pressing and holding the Windows key, then press the R key ("Run"). Type devmgmt.msc.when it opens,right click the topmost icon,,choose "scan for hardware changes"..
sometimes,windows not show your dvd drive,unless you put a disk in.
Sep 15, 2017 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
I need to fix a problem with my Sony DVD RW DRU- 180A. I get error code 39. The computer doesn't seem to recognize the DVD player.
More than likey a fault in the DVD player.
Did it work recently?? If so then probably faulty.
Check internal cable and even try another one, I have had the occasional cable fail.
Dec 22, 2009 | Sony DRU 180A - Disk drive - DVD RW ( R...
CD drive doesnt recognize a dvd
Sorry to say, but a CD drive cannot read DVD's. You need a DVD reader. Thus, the CD drive will not recognize DVD media and tell you no valid disc is in the drive. I recommend buying a DVD RW (reader/writer), as they are inexpensive and enable you to burn DVDs as well as read them.
Jan 01, 2009 | Dell Dimension 3100 PC Desktop
Adding another DVD RAM drive on gateway computer
I made one drive master, the other one like a slave
Dec 14, 2008 | Panasonic SW-9585 DVD±RW Dual Layer...
My LH20A1p186c Lite on dvd writer will not do anything. A simple swap into my comp with 3 cables and the comp. does not recognize the new hardware. In fact both dvd and old cd player appear tp be one...
Check the Master Slave jumper on the back of the drives. If using 2 drives on 1 cable, make sure one is set to master and the other is set to slave. The jumper positions usually are labeled on the top of the drive as "M" and "S"
If you have them set to the same, both drives won't work.
If the drive is sharing cable with a hard drive, try changing the M/S setting.
Mar 31, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
GSA-2166D recognized by computer but does not recogniz media?
Try removing the device from device manager, then reboot. Windows should then re-detect the device and re-install the drivers for it. If that doesn't work, try the device on another computer. If it still doesn't work, it's probably defective.
Jan 27, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
Toshiba Satellite M45-S331 Notebook Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
