Question about Philips 60PP9200D Television
No Power to the TV
Tv does not turn on. The power light comes on but a picture does not. I counted the green flashes(6 slow and 8 fast). I also have tryed every thing the user manual told me to. PLEASE HELP!!!!
Had the same thing on my 50fx20b, (same chassis)replaced the stks & one resistor. works perfect now.
Posted on Sep 29, 2007
How do I fix my Sony TV?
please one thing remember that red led blinking indicate specie fault please watch red light count and find the correct fault which is written below
Monitoring Items Number of Flashes of red led Main Power Supply Voltage Error 2
Backlight Error 6
Internal Temperature Error 7
Audio Error 8
Digital FE Error 10
Trident Error 11
Balancer Error 13
T-CON Error 14
Sep 22, 2017 | Sony Televison & Video
If you turn it on and the, Power/Standby green light blinks slow 6 times; then it becomes a red fast blink 6 times, pause, then continues to blink red fast 6 times, again and again. this means when it's blinking 6 times is indication of electrical circuitry malfunction. The Television will need service.
Sep 30, 2014 | Sony Televison & Video
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
My tv does not come on.A green light is flashing above my timer button. No picture.
The green light flashing is an error code. Count the number of flashes and it will tell the issue. Write back once you've counted the flashes. Also, was the TV having any issues before this? Was there a recent storm or power surge?
Oct 20, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The TV (Dynex DX-LCD32) will not come on. The
I have a DX LVD33 power light is red and no picture or sound screen is black. Please advise.
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
When you hit the power button on the tv it will click, turn green for a second and then turn off. you never see a picture on the tv itself, and it does this constently. how do i get the tv to turn on and...
hi if your tv is a rear projection , and when you switch the tv on you say the green light comes on and then goes off , watch the light it should flash , you need to count the flashes the number of flashes give s a code if it flashes about 6 times i think it is , then this means the bulb has gone which is very common ,this is why the tv doesnt turn on . Now if this is the case the bulbs (are you sitting down ) sell for around £250 but if you look on ebay they sell for around £70 i hope this helps .
Jul 07, 2009 | Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Philips 60PP9200D Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
