Question about Sony PlayStation 2 (PS2) Console
Wont work! Ok, well when we moved into our new house, the ps2 worked fine, until we got an airial for the t.v put in!Now it'll turn on, but no picture or sound will come onto the t.v. We've even left the channel that the console works on blank! please help!i'm dying of boredom!!
Thank you all so much!thanks, to all the advice you gave me, i gor it working with some help, (and it took a lot of help, since i have no idea when it comes to this kind of stuff!), we got it working!
Posted on Oct 02, 2007
  • 709 Answers
Hi,Polly2, To determine if the TV input is ok, Hook something else into the input you know is working. This could be a VCR or DVD player. If you do not have a set of AV cables, you can get them at Wal-Mart. They are the ones that have Red, White and yellow RCA connector on both ends of the wire. If your TV input is not working, then you need to get VCR to go between your PS2 and the TV. Hooking the VCR in by Cable and putting the PS2 into the RCA connectors and slecting Line or A/V input on the VCR and watching the VCR on Channels 3 or 4. If your PS2 is not putting out Video, I suggest you wiggle the A/V connectorwhere it connects to the PS2. Most PS2 and other Game console develop problems with the A/V connection. Youi can get a Aftermarket A/V Cable on Ebay that is all plastic and it works better than the Original Connector that has metal. If you would like, the Playstation Clinic can fix the PS2 fopr a reasonable price. www.playstationclinic.com
  • 363 Answers
Use the video input on your TV instead of the antenna input. You get better quality that way.
Posted on Sep 30, 2007
    Problem Solver:
  • 14 Answers
SOUNDS LIKE A TV INPUT PROBLEM, THERE MAY BE 3 LINE INPUTS L1, L2, PLUS REGULAR CHANNELS, OTHERWISE WHO EVER PUT YOU ANTENEA IN HOOKED IT UP JUST FOR THAT.
Take out the arieal when u wanna play
I can be that ur playstation wire is not gud....
SOURCE:
Unable to watch ITV, Channels 4 and 5, Frreview on my television.
try and do a res set on your freeviev to re find the channels sometimes works or you may have a damaged wire from your airial due to weather or water damage
Jun 16, 2016 | Televison & Video
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My printer was working fine until I moved. Once I
check the rating is correct. if the plug has a fuse check that. try a different wall socket
May 09, 2010 | Office Equipment & Supplies
I have just turned on my brand new PS2. I can select English fine but then when it goes to the next screen ('time zone') it won't let me select. The X button doesn't function at all. I can't move forward....
I will suggest that you try your pad on another console if its OK, if its fine and working then do this when you put on the console just unplug the power cable from the console not the power switch. cheers
Dec 17, 2009 | Sony PlayStation 2 (PS2) Console
Play station 2 slim
its gotta be a console defect or result of an accident send it in to sony or buy a new one
Sep 20, 2008 | Video Game Consoles & Games
Playstation 2 problems
The PS2 Works fine right correct?? If it does and you want to fix the Laser do the following :
Step 1 Turn off the PS2 if on.
Step 2 make the PS2 lie down on its back where the PS2 logo is not seen.
Step 3 Take off the Rubber Squares which are located from all 4 corners and take out the screws using a screw driver.
Step 4 Take off the lid of the PS2 after the screws are taken out.
Step 5 near the light of the PS2 were it shows the Green and blue light is a box where the PS2 disc runs.
Step 6 screw the top of the box and you should see a disc if not taken out and underneath the disc is the lens use alcohol and gently wipe the lens with a Q-Tip after doing so put the lid out of box back on and open the disc drive and put a game in it should work or just get a new PS2 Slim.
Jun 22, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 wont play
did you guys try moving the ting in the back like this try moving it in and out or around 86696c4.gifand if that doesnt work then try getting it checked out by sony or getting a tecnition to see it.
May 25, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 certain game irratic
Sir, you probably have been playing this game for a long time or u might have mishandled it,that might have cause a portion of data on disc to be erased.You might see the scratches on disc your self.....the scratches on disc cause usually the same problem i,e some time game works fine but sometimes it wont work.....you chould consider buying new Disc of FIFA 08......the problem can also be with your lens get your lens cleaned by some lens cleaning CD or do it yourself (you'll just need one screw driver) carefully with a piece of clothe or tissue without touching the lens....Hope that might solve your problem
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
Won't load certain disc
Buy a new one. I try all thwe solutins you can bring up. none work except a new game!!!
Dec 28, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
