Question about LG (GCC4521BK) CD-RW/DVD-ROM (Combo) Burner
Can't burn cds
It continues to request a blank cds or check for damaged cds. I uninstalled and then reinstalled the program and it didn't help.
    Champion:
  • 231 Answers
The problem request has some holes in it but one suggestion is the disks you are using may not be readaqble by the drive itself. look up the drive on the web and see that the disk is supported. meaning some suuport cd/rw +/- some only support cd/r+ or cd/r- or cd/rw+or cd/rw- there are many different formats so be sure the product youve purchase is supported.
Posted on Jul 07, 2009
  • 661 Answers
Check your compilation, it is possible that you are trying to burn more data than you can write to a blank CD, in which case it will ask for a cd with the right capacity. 80 min CD-Rs can have 700MB written to them. if you are trying to write more than this the software will reject the blank as not having the right capacity.
Posted on Oct 01, 2007
SOURCE:
My burner plays and reads fine, but not able to burn cd. have tried 24x and 16x instead of 48x, still didn't work. it detects the blank cd well and would start burning, but after 15 seconds, stopped...
Hi bcwailing ,
The problem that you have described, indicates that your DVD-RAM is not working properly, perhaps the lens has been damaged or the software that you are using for burning the cd is not functioning properly due to change in settings, I would recommend you to do the following steps and check if it works :-
  1. Make sure that the software that you are using to burn the CD , is working properly ,a good idea would be to uninstall and reinstall the software , I believe this should help you out.
  2. If the above trick does not work ,then you can use your inbuilt windows cd writer to test write a cd , by right clicking the files you want to burn and select the send to option and then select the write these files to cd or selected the rewritable disc option.
  3. If the above method does not work , then you need to get a replacement for your DVD-RAM drive , in case it's under warranty , or you need to buy a new one , if it's damaged out of warranty, there are people who try to ask a third party vendo to chage lens , but it's not assured and could waste your valuable time and money.
Hope this helps...:)
May 12, 2011 | LG GSA-H55N DVD-RAM Burner
When i put cds in it works when i put a dvd in i go to computer the drive shows nothing but when i put a blank dvd in it shows it but cant burn nothing to it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 27, 2010 | Lite On LH-18A1P DVD RW Dual Layer Burner
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Finalizing Fails
uninstall both programs and reinstall only one and then try to burn it may be a driver conflick
Jul 13, 2009 | Computers & Internet
Can't burn Cds on Itunes
This program is helpful for burning pretty much anything.
Since I got this I don't use anything else.
If it persists even after this program, you may need a new CD/DVD burner.
Jul 11, 2009 | Apple iTunes
I cant burn cds or dvds with nero startsmart
Do you have the original disk or program?
If so just uninstall Nero and BurnRights then just reinstall Nero.
Apr 22, 2009 | Compaq Computers & Internet
I have just brought a new pack of blank CD's, i am
Its a common problem with CDs. Check that your CD drive can PLAY CDs. If so either the CD drives optical head is dirty or your CD pack are low quality. CDs damage real easy. Try putting another CD, another brand or you must use CD doctor-something like that. Did that help
Mar 10, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Burning CDs
Do you experience this issue only with CD's or does it also occur with blank DVD's?
Oct 01, 2007 | LG (GSA-5169D) DVD RW Dual Layer Burner
Open Questions:
See all LG (GCC4521BK) CD-RW/DVD-ROM (Combo) Burner Questions
LG (GCC4521BK) CD-RW/DVD-ROM (Combo) Burner Logo
130 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
