Question about RCA F25432 25" TV
Rca f25432 when tv is on audio is find but the pic is blury and you cant read anything on menu guide
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Picture blury problem is due to 1 focus wire loose or disconnected due to long life of connection.this wire is in crt base. 2 focus control mistunned. 3 low voltage on crt electodes. 4 if tv is old then crt is getting weak. 5 crt base or connector loose hope this helps. good luck
Posted on Sep 29, 2007
6ya staff
SOURCE:
Rca crt tv guide plus wont turn off for several minutes after turning on tv and dish. I have a satellite dish so removing the zip code causes picture to become snowy and whit horizontal and vertical s
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | RCA F25432 25" TV
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
Picked up tv from friend and cant get it to work
yes. you need to reset guide plus+. with factory tv remote, press.... menu, 7, 1, go-back, tv........ then press menu, 7, 1 , go-back, who-input....... then it will ask you to set up tv with your zip-code.
Nov 09, 2009 | RCA Televison & Video
Rca 25" f27227e
when you bring the menu up on the screen one of the items will let you select cable; another item will let the set autoprogram, let it run through all the channels and it will select what channels you should receive-then you can do channel up/down.
May 08, 2008 | RCA F25432 25" TV
How to use DVD player along with cable box wih this tv
The audio out jacks in the back of the cable box can support up to 5.1 channels of audio to a home theater system. Take the DVD player and plug it into the TV with only the video cable and the audio cables into the theater syste. If you have and questions you can ask and if pictures are needed than I can post them.
Apr 20, 2008 | RCA F25432 25" TV
Model number F25432TX1
From your cable box you can use the audio outputs to port it through to your home theater system.
RCA F25432 25in
If you ONLY have an Antenna or Cable input, you are going to need a Video & Audio to RF converter.. This connects to ya DVD Video & Sound OUT, and then connects to ya sets Antenna IN. This device converts ya Video & Audio signal to Radio Frequency Signal that can be "Received" by ya set. (Basically a low power TV transmitter) This is the only way I know of, if ya haven't got any other Inputs into a set.
Aug 15, 2007 | RCA F25432 25" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA Model number F25432
the horizontal output transistor my be shorted out, or the flyback transformer my be open? Have you unsoldered and tested? If you are not a technician, or have no experience I would not suggest to work on the tv yourself. good luck, Mike
Nov 27, 2006 | RCA F25432 25" TV
RCA F25432 25" TV Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
