Question about Sony Ericsson W300 Cellular Phone
W300i Hi...Phone keeps turning itself off...Thanks
  • hamboner2004 Nov 04, 2007
    the phone works normally until I get into the menu and start scrolling. After less than a minute a blank screen shows up and if i rerove the battery and adjust the sim card, it will start up again.
    hamboner2004
  • eddy666 Nov 11, 2007
    my phone switches off and camera does not work. had it taken into where purchased and told that there was water damage inside.(after 3 weeks at repair). i refuted this as phone was 2 days old and had never been wet but phones 4 u claimed it was my fault and nothing could be done!!!! no replacement or refund.
  • 425 Answers
Hi
probably your phone encounters software problem or software corrupted.  have your phone reprogrammed to a service center nearest you.
Posted on Oct 19, 2007
OKAY I JUST FIXED MY PHONE WITH THE SAME PROBLEM. I AM SO MAD RIGHT NOW THAT CINGULAR NOR SONY COULD TELL ME THIS SOONER!!!!! IDIOTS!!!!
Okay with my phone..it would power up just fine..and then like 1-2 minutes later it would just freeze up or turn on/off. So in order for this too work you need to be able to quickly guide through your phone menu and do a MASTER RESET FOR YOUR PHONE.
You can follow these instructions at CINGULARS WEBSITE
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=55213&isSrch=Yes
Or just follow these instructions
  • From the standby screen, press Menu.
  • Scroll to and select Settings.
  • Scroll to and select General.
  • Scroll to and select Master Reset.
  • THEN CHOOSE RESET DEVICE (YOU WILL LOSE ALL YOUR PICTURES AND STUFF..but since you have your SIM CARD don't worry about your phone numbers..you will still have them)
    • Reset Device: Clears all user-entered info, resets all settings, and deletes all configurations for MEdia Net access and e-mail. Phone will be restored to factory settings.
    • REMEMBER CHOOSE RESET DEVICE (NOT SETTINGS)
  • Screen will display "Phone will be restarted", press Continue.
  • MY PHONE FROZE UP AFTER DOING THE RESET DEVICE.
    UPON DOING THIS I TOOK THE BATTERY OUT AND PUT IT BACK IN AND RE-STARTED THE PHONE. THE INTIAL SONY ERRICSON THAT POPPED UP STAYED on the screen alittle longer than usual. But just be patient. Eventually i got this scrolling white bar that said please wait. Eventually it got to the end..and the phone begins to take you through the configuration process. PHONE FIXED. IT HAS NOT SHUT OFF OR FROZEN AGAIN
    AGAIN YOU HAVE TO BE VERY QUICK IF YOUR PHONE SHUTS OFF QUICKLY..BUT TRUST ME THIS WORKED FOR ME.
    Posted on Apr 17, 2009
    • 3 Answers
    My phone has a lock and i dont noe the code, i tryed using a diff sim card phone was still locked
    Posted on Feb 20, 2008
    SOURCE:
    Unlock my sony ericson w300i cell phone
    There are several methods for unlocking mobile phones, but codes are best one, because it is easy and safe also,
    you can get the unlock code for your mobile phone, through this site http://www.theunlockspot.com/sony-ericsson-w300i/rs10wp9/
    It provides the step by step instructions and easy methods for unlocking mobile phones at a reliable cost itself..........
    Nov 07, 2010 | Lenmar Cellular Phone Battery for Sony...
    Sony Ericsson W300i
    your imie number is located under the battery of the phone. it is a 15 digit number. or to access it from within the phone you press *#06# and it will show up
    Apr 19, 2009 | Jabra Sony Ericsson W300 / w300i / W550i /...
    My w300i fido when closed it turns off! why? eventhough i didn't closed it hard!
    RONJNF - your board could be damaged so take the phone to a mobile center and have it fix.
    CORBEN - try upgrading the firmware to correct this issue
    AUD + CROTTY - try having the phone flash to correct this issue
    Aug 29, 2008 | Sony Ericsson W300 Cellular Phone
    Sony erricsom w300i
    I have a w300i phone.I had put on my phone code but now I have forgotten it plz give me unlock code immediately.
    Aug 17, 2008 | Cell Phones
    W300i phone displays white screen
    Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
    http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
    Jun 16, 2008 | Sony Ericsson W300 Cellular Phone
    Hanged? or flex?
    Blinking screen-black and white
    hi your sony got the white screen of death syndrom, you will need to flash it either with wotanserver or a professional repair shop. YOU WILL LOSE ALL YOUR INFO, but at least the phone will work after.
    if you need a hand we can do it for you.
    thanks
    Jan 30, 2008 | Sony Ericsson W300 Cellular Phone
    It is slow with memory card provided with mobile 256mb.
    hi ,
    u can go for max512 mb..dont go 1 gb as this will hamper the speed of ur mobile..& if u switch to 512 mb..do try to keep all the stuff in memory card rather than sim memory..transfer mostly all the things from phone memory to mem card.This will sort the speed problem of ur mobile
    Thanks
    Gizmo1
    Oct 19, 2007 | Sony Ericsson W300 Cellular Phone
    W300i Transfer Error
    Unplug phone from any connections. Remove battery, Keep power button pressed for 30 seconds. Insert battery, Turn on phone.
    Sep 27, 2007 | Cell Phones
    Sony Ericsson W300 Cellular Phone Logo
    561 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Damen Wong
    Damen Wong
    Ekse
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
