Question about Maytag Neptune MAH5500B Front Load Washer
Will not start
The control panel is unresponsive most of the time, although intermediately since the problem appeared it has worked. Unplugging does little. No error codes. Sometimes the lights will blink on the panel and the off button works. When start is pressed from off - it might start so be ready... The door appears to be locking fine when the machine runs and the cycle (whatever the lottery brings up) runs to completion.
  • MrKirk Oct 03, 2007
    Follow up from MrKirk: I ended up completely disassembling the main board (which looks nothing like some of the on-line pictures I found addressing bad resistors, etc.). I took particular care with the connector for the keypad and connected/disconnected several times before reinstalling.
    After running the keypad diagnostic the washer sprung to life. And although my teenager quickly confused it, I have been able to clear any errors that have occured with taking it apart again. So far so good.
  • 164 Answers
I would go with the touchpad. my experience says when the main computer goes its gone. touchpads when they start to wear sometimes have spots that will work. change the touchpad
Posted on Sep 29, 2007
  • 447 Answers
Sounds to me like the main computer is malfunctioniong could also be the touchpad but that is less likely.
  • joey  shearer
    joey shearer Oct 03, 2007
    yeah id say touchpad too although i havent had any fail
Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Nov 28, 2014 | Office Equipment & Supplies
Whirlpool Dishwasher will not start
Contact appliance repairman,
sounds like either a control problem, or the is a problem with the solenoid that opens up to let water in the dishwasher at initial start.
Jul 09, 2013 | Dishwashers
Dishwasher control panel unresponsive
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Hopefully some of that helps!
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
Technika 32-270 LCD TV won't stop scanning
Need help stopping scan on tv, won't turn on and no remote will activate anything on the monitor. Help flat screen tv.sanyo keeps on percenting
Dec 31, 2011 | Televison & Video
Both the bake and broil oven elements do not heat up / they are unresponsive. I can set the oven temp but on the control panel and it appears that everything is OK there I've replaced both elements and...
Must check the the voltage of 240 coming in to the oven sometime there is 120 volts which will light up the control panel but not enough to turn on the heat elements also check the wiring diagram some times there are cut off switches between the control panel and heat elements those can be bad too!
Jan 14, 2011 | Ovens
DVD starts to play, then freezes up. Unplugging
Buy a new one for $159... post old one PLUS new un-needed speakers on Craig’s List. Problem Solved.
Nov 22, 2009 | Philips HTS3566D/37 Theater System
Machine beeps but won't start
does it say do in the display as if the door is open??
Oct 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
254 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
